Question about Samsung HCM5525W 55" Rear Projection Television
Ghosts our HCM5525W started producing blue and yellow ghosts but the main picture appears to be alright at least color wise. What could be wrong? Also is it costly to repair?
    Master:
  • 788 Answers
Have you tried adjusting the blue convergence in the TVs menu? It's on page 3.4 of the manual here: http://downloadcenter.samsung.com/content/UM/200306/20030618174051718_AA68-01509D.pdf
If you did try to adjust and it's doesn't move or you cannot get it to converge then it's probably the convergence board that is malfunctioning. The updated part number for the board is: AA95-01799G. Google it, you can buy it from many different locations for under $100.
Posted on Apr 14, 2008
  • Dean Joly
    Dean Joly Apr 14, 2008
    The proper part # for the convergence board is: AA95-01799G
    The part Jaime867 pointed to is the power board.
  • Dean Joly
    Dean Joly Apr 22, 2008
    Thank you! Glad to be of service.
    Sergeant:
    Champion:
  • 256 Answers
In Image Quality check Adjustable Color Temp it, please change the settings.
  • 2,323 Answers
It looks like you have a convergence problem with your TV if you are not able to align the colors correctly.
You will need to replace the convergence assembly found in this link.
  • Jaime Hernandez Apr 14, 2008
    Thanks for the correction machine. Is the board number you mention the sub-conversion board or the one that also controls the magic focus?
    The reason I ask is because i do not see the SKT ICs on it.
    I meant the the sub-convergence board (Flash focus).
  • 472 Answers
Your TV needs to have the convergence adjusted. There will be an option for this in your setup menu and will take about 30minutes to an hour to complete (and a few stiff drinks won't hurt either)
Inside the set are 3 tubes, Red, Green and Blue. They all have to point at the exact same spot or you end yup with the ghosts as you have.
Hope it helps
    Master:
    Sergeant:
  • 460 Answers
How old is ur tv...? Cos the wear & tear is the cause for this ghost appearance. The repair for this is only temporarily. It can not be eliminated completely.
Generally the blue ad yellow colour can be removed by a tool which is available with a tv technician. It is not very expensive to do this. Hoping to hear from you.
Thankyou
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Too much yellow
change crt coolant on blue and maybe the red if he`s contamined.
Apr 18, 2010 | Samsung HCM5525W 55" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Yellow, blue and green ghosting of picture. Convergence mode will not allow realignment of the red and blue lines
Hi,it sounds like a light engine problem.Lcd Technology uses 3 chips blue,green and red that create the image ,when they start to fail color discoloration will occur.If it's an Dlp pay attention to sounds of buzzing,whirling and high pitch sounds because it could be your colro wheel.
Oct 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
JVC TH-C5 DVD plpayer....no color when playing DVD's, but color
You might have the connections wrong. If there is component in on you tv(red,green,blue) then use the for the best picture. Other wise use the yellow composite video out to the yellow video in on your tv
Dec 12, 2008 | JVC TH-C5 System
Red and yellow ghosting.
this would be because your color guns are off. The green and blue are still alright which makes the green but the red is off so it makes the red shadow. A quick and cheap fix, just call a repair guy. wouldnt reccomend a diy since its something easy to mess up.
Oct 22, 2008 | Televison & Video
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
Ghosts
pls turn on your unit & open fc in front of mirror pls plug all compenented with pcb & panel & after some time the image will be clear
Apr 16, 2008 | Samsung HCM5525W 55" Rear Projection...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
114 people viewed this question
Henry  Thomas
Henry Thomas
