Maytag MZD2766GES Side by Side Refrigerator Logo
Posted on Jun 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezes food, adjusting thermostat does not help, a slap on the control seems to fix the problem for a day or two. model msd2542v
Chuck
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Jun 21, 2010
 Chuck
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
79088
Points
573
The thermostat's contacts are sticking and needs replacement. By slapping the side you are opening the thermostat contacts until the stick again.
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Food on top shelf is freezing
Not sure what model you have so I need to guess that it only has a thermostat control that regulates temperature? Can you post the Model Number? If your model only uses the temperature control to regulate temperatures then I suspect that the temperature control is at fault and needs replaced. Spare parts HERE Can you locate your model number? Click HERE I am here should you need me, Thanks John TrippAppliance 911
Contact Me Here
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Samsung refirgerator freezing food.
your damper door is freezing fully open between the freezer and refrige compartment defrost it,then adjust the cold control to make sure its controlling the door position,itsound as if your door seals may be letting in warm air that condenses and freezes on things check this too
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Frig temp not stable
Chances are your control dial is bad, your thermostat has gone bad or your compressor has freezen over. As bad as it may seem to trouble shoot this, unplug your frig., to "defrost" then plug back in. If this does not solve the problem, you may need to replace the thermostat or control dial.
1helpful
2answers
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
