Question about Xerox WorkCentre XD155DF Laser Printer
Paper jamming This copier will jam 1/2 way thru the printing process. Part of the sheet will have printing on it. We have tried different paper and trays. Something causes it to bunch up and jam versus letting it exit the machine.
    President:
  • 2,072 Answers
The fuser drive gear is most likely bad.
You can order one at this location.
https://www.partsdrop.com/store/
If you call ask for Britt, he will help you. Best parts service you can ask for. And NO ITS NOT ME. I just deal with them a lot and highly recommend them.
That gear is in the $15 range.
Posted on Apr 14, 2008
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
Printer keeps paper jamming when i go to print. I
check to see if their is a paper size adj. it might be on legal length si=ze and you are getting 1 and 1/2 sheet duration and then shut down
Jul 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Xerox WorkCentre XD155DF Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
