Hi, I do not have a spare whisk, sorry, but am looking for a replacement plastic bowel if you still have a spare one?Hi, I do not have a spare whisk, sorry, but am looking for a replacement plastic bowel if you still have a spare one?
You can't post conmments that contain an email address.
Does the beater shaft turn when there is no load? (bowl is empty) Or it will not turn at all?
It sounds like you have a stripped gear. Your mixer has a nylon/plastic gear inside the mixer and that is 99% of the time what goes wrong. You will want to open the mixer up and inspect all of the gears, but most likely you will need to replace the worm gear, part number W10112253.
Here at MendingShed.com we sell Genuine KitchenAid parts and the items can be found on our website.
I understand the KM32 mixer uses 4.5 oz of Food Grade Mineral Oil in the gearbox, but haven't found a source. Will try Restaurant Supply house or appliance repair.
This sounds to me like the brushes in the motor need to be replaced. You may want to call an area shop which rebuilds electric motors and see if they have a replacement for you. They're not very expensive and fairly easy to replace.
I hope this helps and I hope you have a wonderful holiday season!
See http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
For a chopper attachment; you may need bowl plus rotating blade.
You may also use braun's own spare parts finder at: http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
According to my limited spanish I assume you need spare parts?
I suggest braun.com internationally, and also smallappliance.com if you live in the US.
You will find the 4-digit type number required on the base plate.
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
