Question about LaserJet 3052 All-In-One Printer
My HP 3052 won't print color. Prints in black and white fine but no color! Thanks
  • 1,110 Answers
The LaserJet 3052 is a Black and White only model. It does not PRINT in color. It will SCAN in color.
Posted on Jun 21, 2010
SOURCE:
I put a new hp tri colour cartridge in my printer ....when it prints off test sheets it prints in colour but when i try to print off colour documents it only prints black and white
There's an option under your print setting for color or black and white. When you select to print a window will pop up. make sure that you have the color print selected. Hope this helps
Nov 10, 2013 | HP DeskJet F4280 All In One Printer InkJet
My HP 1315 still prints black and white just fine; however, it no longer prints in color. I have replaced the color cartridge, removed the celophane from the cartridge, cleaned the printer, and alligned...
Open printer properties.
Start --> Printers and Faxes --> (Right-click your printer and select properties)
Check whether you have selected 'Black & White' option for Color property in 'Printing Preferences' (in General tab) and 'Printing Defaults...' (in Advanced tab).
Set it to Color option.
Best of luck!
Aug 31, 2011 | HP PSC 1315 All-In-One InkJet Printer
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did...
go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Won't print in color
hmmm..that's a little weird..guess the settings for color are ok?
Aug 19, 2008 | HP DeskJet 940c InkJet Printer
Is the color cartridge new and do you know how to check the gauge in your control panel for the ink levels?
Jun 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Only prints in black and white
before you print go to the print properties or preferences, in there see if you find a setting that says black/white or color. select color then print.
you may or may not have this option. the older HP ink-jets defaulted to Black/white and you had to manualy select color from the current document you where printing.
Dec 05, 2007 | HP OfficeJet 6110xi All-In-One Thermal...
LaserJet 3052 All-In-One Printer Logo
200 people viewed this question
Top Laser Office Equipment & Supplies Experts
Alun Cox
Norman  J Weimar Jr
Norman J Weimar Jr
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
