Question about JVC GR-D31EK Mini DV Digital Camcorder
Flickering screen from lens but ok in playback mode
My camera has developed a strange symptom, i cannot see what the camera sees through the display screen, it is black and flickery, but playing a tape back it shows up fine! it just suddenly done this! any help would be great!!!
Http://jvc.co.uk/template.php?page=100102
Just ring them up, send out your camera and in a week or two it comes back working fine! I have done it and can say that JVC support is A*
Posted on Jul 31, 2008
My nikon coolpix s70 camera has a black screen but you can still see playback pics opiton button u just can't see take pics anymore it will flash when u take a pic but its still black please help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 19, 2011 | Nikon Cameras
Thre image does not show through the view finder or digital screen
If camera shows previously stored images correctly in playback but does not show live view in camera mode then it is ccd imager chip failure problem.
Replace ccd imager chip in camera by local camera repair shop to fix this issue.
Let me know if symptoms are different as above.
Sep 11, 2010 | Canon PowerShot S2 IS Digital Camera
The display is black through the viewfinder and the screen. The menu displays and pictures taken previously on the memory card can be viewed, but in camera mode, the screen is black and pictures taken are...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Sep 05, 2010 | Canon PowerShot S2 IS Digital Camera
No screen display
First press your DISP or DISPLAY button to make sure that you didn't just accidentally turn off the screen. If that didn't help...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 01, 2009 | Canon PowerShot SD1000 Digital Camera
Screen is black on playback & picture mode
Have you tried taking pictures when the screen is black? Do the pictures also come out black? If so, try putting it in any mode other than auto and turning off the flash (don't want to blind yourself for the next step). Next look down the front of the lens and take a picture. You should see a little flicker in the center of the lens as the shutter opens and closes. If you see this flicker, and you're still getting black pictures, then you likely have again encountered failure of the CCD. Canon will fix this again for you for free. See the following:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
But if no flicker or movement is seen down the center of the lens when you took the picture, then you likely have a stuck shutter. Canon will not fix this for free. But no matter, there are a couple simple fixes for this that don't require opening the camera: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 21, 2009 | Canon PowerShot A75 Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Black screen through screen and eye view finder
Jun 07, 2009 | Canon PowerShot SD870 IS Digital Camera
Image flicker when viewing pictures in playback mode
You have the camera in Highlights mode.. while in playback use the up,down,right,left pad press it up and it will go through different displays like what settings you had the camera in when you took the picture then there is a graph screen... after that one is the highlights display which is what you have it on. Push up one more time to have it on regular playback mode. The manual explains this much better than I just did. If you have the manual you should check it out if my instructions dont help.
Mar 30, 2009 | Nikon D60 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Your camera has problem in Lens mechanism. If Lens doesn't open properly, camera will not show picture at all. There would be Loading Motor section demaged in Lens mechanism and it needs to be replaced to work camera OK.
Now come to blue screen in playback mode, This model doesn't have internal memory, so you need memory stick/ card to see previously taken pictures.
Jun 21, 2008 | Cameras
Strange picture appears in CCD
I see this problem everyday : the CCD sensor is faulty ( see enclosed pic from a canon camera with similar specs ) this is why you can not capture normal undistorted images but have no problem with playback .Fortunately Casio will repair this free of charge so contact your agent.1057f04.jpg
Nov 14, 2007 | Casio QV-R41 Digital Camera
JVC GR-D31EK Mini DV Digital Camcorder Logo
111 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
