FixYa.com
Tags:
Intel Foxconn: Foxconn CPU Cooler For P4 478 3.4GHz CPU Cooling Kit
P4 3.4 GHz Problem
By pawa - usenet poster
Hey!
I have bought to Medion PC's with Microstar MB, Intel P4 3.4 GHz "550" CPU
and Windows XP Pro and when I use my PremierePro 1.0 it crashes!
PP starts to render and dies. It just close down without any warnings.
The same do EncoreDVD 1.0.1
Anybody knows a solution ?
I know I can bye v 1.5 of the applications, but will it help, or will the
kids just lose ther chrismas presents an go crazy :-) ?
The PC's work fine!
Regards
Michael Lund S??rensen
www.milux.dk    www.gromit.dk/dvd
www.recordere.dk
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Ross
Ross - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"Michael Lund S??rensen" <laeses-i @gromit.dk> wrote in message
Yup, I recommend NEVER upgrading from one version to another, always do a
fresh install.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
You might have a problem with your XP install on that machine, kernel issue
possibly.
Solution #3
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
Could you explain that a little bit more, plz!
It's a new machine, 'born' with XP home an upgraded to XP pro.
There is allmost nothing on the machine.
The HT was enabled under upgrade.
Du you think it's better if I clean the harddrive and installe the XP Pro as
the first OS ? Shoud it help?
Best regards
www.recordere.dk
Solution #4
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
Didn't help at all! But now it is done.
Best regards
www.recordere.dk
Solution #5
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
John Howells  skrev :
Yes!
No, the HT is a MUST !
Regards
www.recordere.dk
Solution #6
Not Rated (0)
Gary10
Rating: 0%, 0 votes
I'd have to say that based on your description, works perfect on your P4
3Ghz, crashes on your P4 3.4GHz, then there really is a problem with the
3.4Ghz PC.
Solution #7
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
There is no problems in ThrottleWatch. The MSI monitor application PCAlert 4
says 61 C at max and 55 C at normal.
Regards
www.recordere.dk
Solution #8
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
Michael Lund S??rensen  skrev :
It seems to work with HT disabled!
I have to live with that until I find a better solution.
Thanks!
Best Regards - happy xmas!
www.recordere.dk
Solution #9
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
Yes, but the PC works fine! It ran Prim95 for 3 hours yesterday wit at
temperature of 61 C, case 55 C and ambient 25 C.
I ran ThrottleWatch and System monitor at the same time, and it all looked
perfect!
I ran PowerDVD and saw a film at the same time (it stopped from time to
time).
The PC seems to work perfect, except with Premiere and Encore.
I (or the company) will keep the PC ('s) and upgrade PP and E.
Regards
www.recordere.dk
Solution #10
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
Does the older P4 have Hyper-Threading enabled (do you see two "CPU Usage
History" graphs in the Performance tab of the Task Manager)? Have you tried
disabling it in the BIOS on the new PC?
John Howells
Solution #11
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
The OP wasn't clear ... did Premiere crash? or did Windows crash?
If it's Premiere that crashed ... well, welcome to the club. I gave up on
Premiere two years ago. I couldn't keep it running long enough to get any
useful work done. It would just hang. But Windows was unaffected.
Solution #12
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
Thanks John, I will try the throttle watch
Best regards
www.recordere.dk
Solution #13
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
It could be any number of things but most likely it's one of two things.
Heat or crappy software.
Heat: Download Prime95 and run it for a cuppla hours. If it produces NO
errors you can rule out heat.
Crappy software: Both titles you mention are notorious for crashing on NT
based O/Ses. Download the free trial of DVD Lab and try a project or two. If
it works  without error ... buy it.
Solution #14
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Octavian  skrev :
Premiere closes down with a notic 'Unexpected end of application'.
Windows an any other application keeps running.
I's the same Premiere version as we have been using for a long time, and it
works fine on P4 3.0 PC's and my XP3000+
But the new P4 with 1 MB cache, 3,4 GHz CPU is running much faster than the
old and we want to switch PC's.
The newone have even SCART connectrion with RGB out
Regards
www.recordere.dk
Solution #15
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
sedum  skrev :
There where 512 MB, now there is 1.5 GB dual DDR2 Samsung/800 MHz
I will takt the original memory out. The 'new' are old and well used.
Yes, that a posibility, but to new PC's with same fault ?
The CPU has a major heatsink and a fan. The fan is quiet when I begin, but
rater noise when the PC's have to work hard.
Yes. I have another I can put on the harddrive.
Absolutly good ideas, BUT other applications don't die! If it was a power
problem, the other applications would close down to. The don't.
Thanks, David !
Best regards
www.recordere.dk
Solution #16
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
"sedum" <s @nonsense.com> wrote
Although one should never say never, with a P4 that *SHOULD* not be a
problem, as it should automatically throttle back when it gets hot, to
remain within its allowed temperature.
Even so, this http://www.panopsys.com/thrott lewatch.htm useful little
utility can help. I used it on my P4 system to set the fan speed such that,
when working hard for an extended period recoding video, it was as quiet as
possible without ever needing to throttle back.
John Howells
Solution #17
Not Rated (0)
Green1
Rating: 0%, 0 votes
On Wed, 8 Dec 2004 01:01:18 +0100, "Michael Lund S??rensen"
PC's that crash, in my experience, can be down to:
1. Not enough memory. These video applications need a lot. Probably
need at least 500MBytes.
2. A memory fault. Normal use may not find the problem, but large
applications will. If you have two memory cards, try each on its own
and see what happens.
3. Processor cooling. When CPU's start to work for 100% of the time as
they do in video applications, they start to warm up and can overheat
if the fan is not doing its job properly. (I have a software
temperature monitor to check).
4. Power Supply's output not stable or intermittent. Difficult to
troubleshoot without specialist equipment.  Swap out best way.
Hope that helps
David
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
