Question about Panasonic PT-47WX49 47" Rear Projection Television
Convergence for Panasonic 47"
The post from miaqueen on apr 12 was incorrect for the tv. It is a Panasonic pt-47wx42F with convergence problems.Is your fixto replace the stk392-110 convergence ic's still hold true?
  • Panasonic Master
  • 8,617 Answers
Yes it is that set uses the same IC STK392-110 You can get the new ICs at this link and they will provide free installation instructions with pictures as well as free on line tech support instant messaging while you do the repair. heres the link.
http://servicemanuals.vstore.ca/
Posted on Apr 14, 2008
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42F outer most screen cracked
Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Please Help... Strange blue reflection across screen (See image)
Convergence ICs are bad and posibably th eresistors that power them. Its an easy fix if you can solder
Feb 29, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic HDTV Projection PT-47WX42F won't turn on
Your Set is going into shutdown mode due to the convergence section of your television. Thats what 3 blinks mean. It could be just the Convergence ICs and resistors or you may need a new Signal board TNP2AH035 Let Me know if you need further assistance with this problem.
Feb 16, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic- 47wx42f
Changing the convergence amp IC's is usually the first step..
Then let us know.............T.
Dec 02, 2007 | Panasonic PT-47WX53 47" Rear Projection...
No voltage to convergence chips
There are usually 2 micro fuses that resemble 1/4 watt resisters around the power supply, and are usually all green,tan or yellow, and in most cases will have a + or - voltage marked right near these fuses 20 to 25 volts dc typical.
Jun 25, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
238 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
