Question about Toshiba TP61H60 61" Rear Projection Television
Toshiba projection tv tp61h60
When i turn on the tv the light and sound comes on but no pic. when i shut it off a flash gose and i shuts off. can you please help
  • Anonymous May 30, 2008
    I have A toshiba Projection Television TP61H60 and it won't turn on. I heard the click for turning but all it does is blinks the red light on the ON buttom.
    diaz3@dejazzd.com
  • 65 Answers
SOURCE: Toshiba TN43V71 intermittently shut off
needs converge ics
Posted on Dec 09, 2006
Shuttle83
  • 1139 Answers
SOURCE: Toshiba TN43V71 43 in rear projection
Hello WendyOreo,
It sounds like your switching power supply or you High Voltage power supply has malfunctioned. These sections control all power to the TV and can produce the situation you are describing. If you do not have a background in electronics, I would suggest that you have a TV repairperson come over and check your TV out.
I say this because there are voltages in a TV set that can kill, so caution is needed.
I hope this helps
Thank you,
Shuttle83
Posted on Oct 17, 2007
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
Posted on Jan 31, 2008
Slinteriors
  • 8617 Answers
SOURCE: tz61v61 toshiba 61 rptv theaterview
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: toshiba projection tv
your set has a problem with the power supply causeing the set to shotdown. You can get a manual called Toshiba shutdown circuits and power supply troubleshooter that takes you step by step to diagnose your model its available at this link they email it to you almost instantly after purchase and they also provide free tech support in case you need further help. heres the link.
Posted on May 12, 2008
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
I have a toshiba TP61H60 it turns on and then turns off
On this model TV it is more than likely the Connvergence IC's, (2) STK392-110. Also, check all the little green pico fuses, replace as needed. When replacing the IC's resolder all 'jumper' connections in the connvergence area.
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba TP61H60 61" Rear Projection...
T.V. will shut itself off, power light flashes
my toshiba tv shuts itself off after about an hour or so
Jan 18, 2009 | Toshiba TN55V71 55" Rear Projection...
No pic no sound
sometime the overheated ic in the convergence section are the problem I have fix some
Jul 21, 2008 | Toshiba TZ50V51 50" Rear Projection...
Tv shut off
I will need to know the model number of your set and how many times it flashes between pauses. Please respond to this same post.
Jul 02, 2008 | Televison & Video
1996 sony projection tv model kp46s17
does the tv realy shut off or does the pic go away sounds like bad tube
Nov 03, 2007 | Sony KP-61V75 61" Rear Projection...
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba TP61H60 61" Rear Projection Television Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
