Question about Canon PowerShot SD850 IS Digital Camera
Camera does not power on/ off easily
I love my new 850SD, but in the last month I have noticed that it takes several attempts of pushing the button to turn it on or off. I can feel that I am pushing the on/off button, but sometimes it takes about 10 tries before it actually powers on or off. Any ideas?
  • 489 Answers
Hi
The power button on the inside of the camera, not the button you see, has probably been damaged slightly and replacing that assembly would fix the problem.
One solution would be to buy a defective camera online and make one good camera from the two, another is to buy just the part you need or have somebody do the repair for you.
We are an affordable digital camera repair business, (google: DARNTOOTHYSAM) and if I recall correctly the ribbon cable you need that contains that button and the menu buttons is part of the flash assembly... Strange, but true. We can get the part you need and even install it for you, just let us know if we can help.
Good luck from Darntoothysam com
Thomas
Posted on Oct 15, 2008
Power coming in to television, but when I push the power button to turn the tv on; it does not come on.
You may have what I call the hard to turn on issue, look again in the power supply inside the set--follow power cord that goes to it and look for puffy filter caps:
Dec 17, 2012 | Televison & Video
I recently moved & didn't use my Z1 for several months. When I did go to use it, is when the problem started. It will power-up for a second or two & power back down. I love the camera it's been...
The battery must have run down over prolonged storage. It mayhave been stored while still on causing battery shortage. First attempt to power charge for full extent to ascertain if the camera is is in functioning order. Any unobservable faults thereafter equates to usually functionality. goodluck
Jan 29, 2011 | Konica Minolta DiMAGE Z1 Digital Camera
I have a Jazzy1113,it had been unused for several years.I did not take right steps to take care of batteries. I tryed several months ago to start and of course would not,but i do remember some movement...
There is a 7.5 Amp ATO automotive fuse on the rear electronics tray that is probably burnt out. The ammeter will not work when this happens. Also, if you have a bad on-board charger that will inhibit movement of the chair. Unplug the on-board charger and see if you get it to move. Hope this helps.
Jan 04, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Fuji FinePix F30 shutter problem: won't take pictures
Its fairly easily fixed and its a common problem with the F30. The shutter button contact slides off upon impact when dropped, it must be re-aligned so that it makes proper contact and performs normally. All that is needed is the special screw driver for the F30 (easily purchased online, just google it: "screw driver for fuji f30" ) or bring it to your local watch/jewelry repair store and tell them to open it up for you.
We have two F30's and they both have been dropped, both did the same thing with the shutter button. But both were easily fixed. Always keep the camera in a safe place and away from kids, they are very sensitive devices. Use the wrist cord when taking photos.
Nov 19, 2009 | Fuji FinePix F30 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Canon a560
Did you accidentally hit the "DISPLAY" button on the back of your camera? It manually turns the display on and off to save batteries.
Jun 21, 2008 | Canon PowerShot A620 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Taking pictures
This could be due to a jammed lens element preventing the camera from focusing properly. When you push the button the camera attempts to focus the image before it takes the picture. If the focus component in the lens is not moving properly it cannot focus and thus will not take the picture. Do you see the camera attempt to focus the image when you press down the button? If it does not make any noises when you push the button, and the camera does not attempt to focus the image then it is most likely a jammed or malfunctioning focus motor. This would require professional repair.
Feb 19, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Power problem with 450
The LCD goes dark after the camera has been inactive for a time, to save battery. When that happens, you can easily restore the LCD display by half-pressing the shutter. If you want to, you can turn this off by selecting menu-setup-SleepTimeout and turn it off. (I don't recommend it, though, as the LCD always on will drain your battery).
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Canon PowerShot SD850 IS Digital Camera Logo
119 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
