Question about Maytag MMV5165 Microwave Oven
Maytag above the stove microwave not working
Our microwave was working fine until we took it down to paint. We built a new cabinet above the microwave and got rid of the vent on top that we weren't using anyway. There are still vents in the front of the microwave that we thought would kick in. The microwave power is on. We go to heat something up and it doesn't heat up. Any suggestions. The microwave is a couple years old.
  • William Miller
    William Miller May 11, 2010
    Could you please explain speficially what you mean when you said, "got rid of the vent on top that we weren't using anyway"?
    Without proper ventilation, the magnetron can be damaged and destroyed due to overheating.
  • Anonymous Mar 12, 2014
    This is the second microwave that I have put above my stove that quits working. It makes noise but does not heat
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
How do i remove a over the stove microwave?
On a 1-10 scale- this is a 2.
place a cardboard box on the stove to support the microwave once it is free.
Remove power cord from the outlet in the cabinet over the microwave.
In the cabinet over the microwave, locate the 2 mounting screws.
Loosen each one about 6 turns- the microwave should drop down in the front by about 1/2 inch.
Once loose, you can remove both screws completely and allow the front of the oven to rest on the cardboard box.
While supporting the front of the microwave,have a helper remove the cardboard box.
Tricky part...while supporting the front - angled slightly down, lift hard under the rear of the microwave and pull toward you.
Have a helper feed the power cord through the upper cabinet bas as you bring the microwave toward you and slightly down.
Place the microwave on the counter- with a towel in place to prevent scratching the counter.
remove the rear-wall mounted support bracket.
Done
Apr 27, 2014 | Maytag MMV4205 Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How do I install a replacement Frigidaire over the stovetop microwave - professional series, without removing the cabinet above it? I need to know how to best remove the existing microwave.
Remove everything from the inside of the microwave, (such as glass tray). Unplug the microwave, probably in the cabinet above. There are two screws in the cabinet above the microwave, near the front, that supports the front of the microwave. The back is hooked on a mounting plate attached to the wall behind it. An assistant is a good idea though this can be accomplished alone. It is best to move the stove out, if you are going to try alone. Please be carefl there is considerable weight to support here. Support the front of the microwave while the two screws are removed in the cabinet above. Slowly tilt the front of the unit down until you can pull the cord out of the bottom of the cabinet. With the front still tipped down, lift the back from it's support and remove it.
Jul 18, 2009 | Microwave Ovens
How to remove maytag microwave over the stove about 10 yr old
There is a considerable amount of weight to lower. It is an easier removal with the range pulled out and moved to the side. If you choose to move the range, be sure to protect the floor. Unplug the microwave. The plug should be in the cabinet above the range. There are two screws in the cabinet above that screw down into the top and support the front. These are the only fasteners that hold the machine directly. An assistant would be nice to have to help with the weight. While supporting the microwave, remove the two screws and slowly lower the front of the microwave pulling the cord out of the cabinet above as you go. Once the cord is free, tilt the machine down in front until the back can be lifted up off the plate that is fastened to the wall.
Jul 12, 2009 | Maytag MMV4205 Microwave Oven
We have had custom cabinets made for our kitchen and have installed a microwave above the stove and it is to high for my wife, She is 5'4" tall and can hardly see in the micro wave. The carpenter doesn't...
you will also need to consider space between the stove & microwave, but you could go back to your cabinet company and have them make you a dead panel that matches your cabinets for the face side of the microwave. then you will also need three other pieces 1 for each side and 1 for the back! if you want to drop the microwave down 12 inches have your panels cut 12 inches! have your carpenter block in and attach panels, go to a fastner company with 1 of the bolts that the microwave came with to hang it from the cabnit and find or order bolts the compensate for the depth in which you you have your panels built!
May 31, 2009 | Microwave Ovens
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Need help figuring out microwave installation above stove
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5165 Microwave Oven Logo
175 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
