Question about Motorola Mobility HS850 Consumer Headset
I forgot the passkey for the ear piece and need to pair it with a new phone...how do I reset it? Jon
Pass Key is 0000
Posted on Apr 20, 2008
Need to hard reset motorola mini bluetooth h9
try removing the pairing to your phone and pair again. If this does not work try pairing your headset to another phone and if it does it on that phone then something is wrong with the earpiece return for repairs if under warranty or if you are willing to pay for the repairs if out of warranty or replace ear piece all together as they are reasonably priced these days. If the ear piece works fine the other phone something has gone wrong with the bluetooth side of your phone return for repairs or replace depending on what you can afford to do. I hope this helps.
Aug 26, 2012 | Motorola Mobility H9 Mini Bluetooth...
Tip
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
86707
86710
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
I am trying to pair my Plantronics Explorer 220 ear piece to my samsung At&t cell phone, It can not find the passcode # 0000,1111,9999 or 1234. Is there another code i can use?
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
SETTINGS
Time and Date
Phone Settings
Bluetooth
Sound Settings
Network Services
Security
Reset Settings
BLUETOOTH
Discover/
Search
BLUETOOTH
220Plantronics
Headset Passkey
PASSKEY
0000
Step Two:
Prepare Headset-
Pairing Mode
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue.
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with
another device, follow pairing instructions on the next page.
Apr 20, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do I sync my replacement ear piece
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Dec 08, 2010 | Plantronics CS70 Wireless Headset
How do i connect phone with m2300 ear piece
Begin with Headset turned off. Press button for 6 sec. Release button when Light Indicator flashes blue and red. Headset is ready to pair with Bluetooth device. Use your device?s menu to enter pairing mode and select ?320 Plantronics? on the display. When asked for passkey, enter ?0000.?
Mar 28, 2009 | Plantronics Explorer 320 Wireless Headset
Brought new phone and need to connect ear piece
You will need to pair it with your phone. first make sure the headset is off, then put the headset in pairing mode by pressing and holding the answer/end button until a solid blue light appears. then you will need to goto your cell phones bluetooth menu, turn your bluetooth on, then in your bluetooth menu you will need to add a new device or discover a new device depending on the type of cell phone you have. Your phone should find the jabra ear piece if it's in range of your cell phone and will ask if you want to pair with the device, after accepting confirm with the pin of 4 zero's.
Feb 16, 2009 | Jabra BT250 Consumer Headset
Forgot how to sync my PLN-510 Headset with my phone, I recently purchased a new phone and need to sync my bluetooth with the new phone Pantech Slate C530. Please remind me
Hold the up volume and the talk button (the one on the side of the ear piece) down until the status light flashes red then blue.  This places the headsead into pairing mode.
Jan 05, 2009 | Plantronics 510 Voyager Headset - PLN-510...
How to reset samsung wep310 bluetooth headset
connecting my Samsung WEB410 ear piece to motorola phone. Ear piece has been connected to another phone, so I need to know how to reset it to put it in recieving mode?
Oct 29, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Motorola Mobility HS850 Consumer Headset Logo
62 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
