Question about Sony Cyber-Shot DSC-S40 Digital Camera
White Back ground
When I turn my camera on I get a white screen. I can see the pictures from the memory stick on the computer, but can't view them or the menu on the screen. What can I do to fix this issue?
  • Jb1987 Apr 19, 2008
    I have the same problem, the camera turns on to a white blank screen. I can still take pictures but have to use the viewer. I tried pressing the display button but all that does is toggle between a white blank screen and black screen. I could use some help here.
U should try the solution given by Muccion. I did n it worked. Thanx n Bravo to Muccion!!
Posted on May 05, 2008
When turn on camera lcd screen is white instead of show view in front of camera. might be internal shutter stucked.
Not much to go on. I hear a lot about white screens, but don't know what it looks like. Cold be the LED's on the back are lightning and no info is send to the screen. Did you try to change the settings? sometimes the screen is switched off, to save power. Press the display button several times. It is on the top of the control button on the back.
If you take a picture, do you get an image on the memory card? Perhaps you only can see it on the PC.
If you don't get an image (or just a white image) your sensor could be damaged.
Dec 08, 2013 | Sony Cyber-shot® DSC-H20 Digital Camera
What could have happened to my memory stick pro duo? I took pictures and was able to view them perfectly fine. When I went to deveolpe them I put the stick in the wrong slot that was too big. The sti
When you plug this memory stick into your computer and the computer cannot detect this memory stick then the memory stick is damaged and your photos cannot be retrieved.
Jan 06, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A300 Digital Camera
The camera screen is white I am not sure if it is the lens or the screen. It fell
Most likely the screen or the control circuitry was damaged in the fall. One thing you may try to determine if it is the screen or the lens is to take a few picture and then view them on a computer to see if the white screen is replicated in the pictures taken. If it is, then you are most likely looking at a damaged lens. If the pictures turn out fine, but cannot be viewed on the camera, then the screen is the culprit.
Mar 01, 2011 | Cameras
When viewing pictures on camera and File Error shows up across the screen
Format memory stick in camera, format option is available in setup menu of camera.
Note: all files will be deleted on memory stick after format so make sure you have transferred picture files in computer or have back up.
If problem still not solved then put another memory stick in camera as this memory stick seems defective.
Thanks.
Dec 30, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
Accessing pictures on memory stick
Dear LisaLu,
If the file extention of picture i.e JPGE has been changed, camera wont show that picture.
You should paste those pictures in same folder of cyber-shot.
May 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
I think the lens is stuck
Find a new boyfriend. Then, ask him to buy you a new camera.
Nov 12, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
My LCD screen shows a colorful vertical line & then the screen goes white
Hello, The problem is in bad contacts on flat cable from the LCD. Cleaning the cable and the connector can solve the problem. If you need more info please advice. ps: this should be the long term solution.
Apr 21, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
16 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
