Question about LG KG800 Cellular Phone
Screen Hi, The screen went blank and now it's like a mishmash of colors and is divided into three small rectangles. Two on the top and one big rectangle in the bottom of the screen. The two top ones are like extremely bad copies of the original screen. Every is minute and I can't really see who is calling. I can make and receive calls but am unable to send or receive text messages as I can barely see what's on the screen. Thanks in advance.
    Sergeant:
    Champion:
  • 283 Answers
There's 3 problems u can have....replace the lcd., change flex... or faulty display ic .go to your nearest service center...hardware problems...
Posted on Apr 16, 2008
Crownbet screen suddenly reduced60% cannot read
if you on a pc or lap top , right up in the top rh corner you will see three small rectangles
the first one takes the screen off altogether and saves it to the task bar
the second cuts the screen to 60% or back to full screen
the last closes of the browser session.( red cross)
Nov 26, 2016 | Cameras
What to do when an 8022c wall thermostat screen goes blank - no numbers, just the lines dividing the three areas? Pushing reset does nothing.
Pop the cover off and check the battery. Replace if necessary. If it still doesn't work trip the main breaker for the ac unit off wait 1 minute and turn back on. If it still does not work then you have a more technical proble. Could be a bad thermostat or control board in the ac unit.
Jul 03, 2016 | Audio Players & Recorders
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
Tv went double and green and black lines appeared at the top and bottom of the screen
tv has a condition common in rear projection. the geometry and coincidence of the screen is called convergence. this is regular repair in the workshop. I expecting the fail stops in convergence amplifiers (first step of this critical area) because total convergence out of sinc as you are posting can lead to the control of the convergence previous to the amplifiers (is called digital convergence unit). It can increase the cost of the repair. some testing in the bench can divide this decision. But usuallly a simple damage is one color or two colors distortion, your tv shows three of them because this black area visible top and down.
Apr 16, 2009 | Sony KP-51WS510 51" Rear Projection...
A rectangle with sides parallel to the x-y axes and its left-lower corner at (0, 0) is being painted. The rectangle may be thought of as a flat-screen display with almost infinite resolution; initially the...
It would be "cheating" for anybody to do your "homework" from your computer-mathematics class, unless you submit your answer, saying that an EXPERT on FIXYA did all the work on your behalf.
Apr 14, 2009 | Microsoft Windows XP Professional With...
Color toner
try this on the screen you touch system moniter then consumables this should gine you a divided screen on top toner levels on bottom should say change each toner select the ones you want to change
Nov 04, 2008 | Canon imageRUNNER 210S Copier
RCA
The flyback is the big black thing on the deflection board. usally has big red wire coming out the top. THe three small rectangular items are special fusable resistor. or fuses
Sep 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Dark picture (projection tv)
Hi Steve,
The picture is darker because the dust build up on the lamps or CRTs. I would suggest to leave the TV unplug overnight and clean the lamps using a screen cleaner that works better then windex and clean the mirror that reflects the video to the screen if you can get access to it.
Mar 11, 2017 | Televison & Video
LG KG800 Cellular Phone Logo
50 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
