I have aTechnics SA DX940 Receiver I want to connect everything to run thru my Equalizer I need the wiring pictorial for plug jacks between the components I Have A DVD Player,CD player, and VCR My TV is conmnected to cable
  • 4,234 Answers
The only way to utilize an EQ with this receiver is to connect the EQ as if it were a tape. Use the tape-in/tape-out connections and set the reveiver in tape monitor mode.
Dan
Posted on Apr 14, 2008
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
HOW CAN I CONNECT A MIXER TO A TECHNICS SA-DX940 AV
I used the manual downloaded from http://www.manuals365.com/technics/sadx940.html
Try using the final stereo output of the mixer as the input to the CD or Tape or VCR inputs.and use the switches on the fromt of the DX940 as necessary.
The specificatios state input sensitivity is 27 mY so your mixer needs a low output..
No reason it shouldn't work.
Sep 18, 2014 | Technics SA-DX940
I moved and cannot find manuel for sa-dx940 need instruction on how to reconnet wire to t.v. and speaker
The Technics SA-DX940 is made by Panasonic. The manua as a PDF is available here: http://service.us.panasonic.com/OPERMANPDF/SADX940.PDF . The directions for connecting the speakers start on page 14. The connection to the TV is on page 10. To use the SA-DX940 as just external speakers for your TV, connect either the digital audio out from the TV (if it has one) or the RCA audio out from the TV to the matching TV audio in on the SA-DX940.
I hope this helps.
Jun 30, 2011 | Technics SA-DX930 Receiver
Technics 940dx "overload"
Disconnect all speaker wires from the back of the receiver and turn it back on. If overload does not turn on, post a comment and I can walk you thru troubleshooting. If it does, your receiver needs to be serviced. Hope this helps
Jun 25, 2009 | Technics SA-DX940
Technics Receiver SA-DX940 subwoofer
Make sure subwoofer button is pressed and registers that sub is set on, the check dB level adustment for sub channel with remote.
Mar 16, 2009 | Technics SA-DX940
Problem with subwoofer and one off the speakers.
check out the amplifier ic in the receiver unit of subwoofer as the number of ic is IC346JC this has to be replaced.
Mar 13, 2009 | Technics SA-DX940
SA-DX940 recently stopped recognizing digital formats
Make sure you are using a digital connection, optical or coaxle cables must be connected, setting on receiver must match cable being used
Dec 18, 2008 | Technics SA-DX940
Technics SA-DX940
Ratnesh, I have this same receiver and the fan only comes on at certain volume levels. Unfortunately I now live in an apartment and can very rarely listen to it that loud. I had the same problem for a little while until I thought about moving the receiver to the lowest shelf with nothing on top of it. This seems to have worked so far although it does still get quite warm. Good luck!
Aug 04, 2007 | Technics SA-DX940
65 people viewed this question
 Grubhead
Grubhead
