Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Dust is flying!!
I have a very dusty house and also a dog with long hair that is shedding this time of year. When I use the hose, dust flies out all over the place. I keep cleaning the filters, but they don't seem to work anymore. I went to Target (where I bought the vacuum) and they don't have any of the correct filters or belts for this Eureka Ultima. Is there a quick solution or do I need to order parts online?
    President:
  • 1,673 Answers
Bad filters could be the problem. They need to be replaced, some every 3 months or so. Also a clog in the hose or the dirt inlet down by the brush roll.
Posted on Apr 15, 2008
Vacuum is clogged with dog hair. How can clog be removed?
HI, it's Jim from Crucial Vacuum!
If your Shark vacuum is clogged with dog hair there are a number of general maintenance cleaning tips you could perform to help keep your vacuum working at its peak performance.
First let's check out your brush roll. Is there dog hair wrapped around the roll itself? If so remove it by pulling out the dog hair, or use a razor if its tightly wrapped around. Manually rotate the brush roll to help unearth any hidden clogs behind the roll.
If there's dog hair throughout your unit be sure to empty the dust cup after every use. When the dust cup isn't emptied often this leads to clogs and a loss of suction.
Also, be sure to check your vacuums hose for any clogs, or clumps of dog hair. Stretch the hose out as far as you can. If you notice a clog in a hard to reach place use a broom handle to unclog it.
Your Shark vacuums filters may need to be replaced, or washed and may be a source for a lot of the dog hair in your vacuum. Wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 11, 2015 | Shark Vacuums
We have a dyson dc27 total clean, this is the worst vacuum we have ever owned we have dogs so we vacuum about every other day our dogs have fin short hair and its hard to pic it up we have to go over the...
My vacuum engineer friend loves Dysons ~ he says that they keep him in business!!
The only machine that I have found any use on animal hairs is the Miele Cat'n'Dog model.
The turbo brush is excellent.
Dogs shed most of the time so that means to keep onto of the hairs you need to vacuum most of the time (once a day!).
Miele Cat and Dog Complete C3 Canister Vacuum
Pricey but mine is brilliant.
Dyson's are cheaper and now you know why!
Good luck
Apr 30, 2017 | Dyson DC27 Bagless Upright Vacuum
Miele s7000
My question is what kind of dirt are you trying to pick up. Regular dirt does not plug up in twenty minutes. If you see dirt flying around that tells me your vac hose or parts that have a suction is plugged up. Take the hose and hose attachments off and make sure there is no dirt inside.If they are clear check the inside of the vac for dirt as well. Check your filter which is back of the vac bag as it may be plugged as well. The filter should come out to be cleaned.
Dec 21, 2017 | Vacuums
When you remove the hose to use the utensils, the dirt is flying out of the hose at the bottom where the utensil is removed from
Hi Karen. I understand how frustrating this can be. Dust blowing from the bottom hose is normal because the brush is still rotating. If there's excessive dirt flying out, then you may have a clog in the bottom hose.
Here's a quick link to check for clogs: http://www.bissell.com/FAQDetail.aspx?id=1419&cid=ccsocial
Apr 20, 2013 | Bissell 6591 Power Trak Revolution Bagless...
When I try to disconnect the hose in order to use the hand held hose with an attachment, the dust from the bottom flies into the air. How does this opening get blocked off to ensure the dust enters...
It is a matter of Physics. It seems like you have it running when you change the hose. ?? That's a no-no.
Basically you will have o take it apart until you know how it works or wont work
Jan 29, 2011 | Bissell Vacuums
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Vacuum blows out dust/pet hair etc. when in use
try replacing the belt if you havent. it almost sounds like your getting weak aggitation. if thats not bad, check for a clog in the brushroll housing nozzle right on the inside by the tube. Replace the inside hepa filter if you havent within the last 3 months.
Jan 04, 2010 | Hoover U5753-900 WindTunnel Bagless...
I have a kirby g4 vacuum that is 12 years old. it sounds like
About once a month as I have German Shep dogs and cuz of the hair I check all the hoses to make sure they are free of dust bunnies. I also take the bottom plate off the roller, turn the lever to losen the belt and take the roller off. Clean/cut all the strings, hair etc off the roller , check the belt for cracks and burns and replace if need be. Put the roller cover back on, and reconnect the belt.
Then on the side of the machine where the bag attaches, this also slides out to clean. Sometimes heavier items will get stuck in there so that dog hair and larger items cannot pass to the bag and it clogs. This will make your suction very low.
Also a good check inside the bag compartment and clean with the attachment hose if need be, helps a great deal with ordor and dust when turned on. Especially if you have dogs/dander and hair. Ive also put carpet fresh inside my bag to keep the doggy ordor down.
Jan 28, 2009 | Kirby G4 Bagged Upright Vacuum
Lift-Off Pet Hair vacuum doesn't lift off pet hair!
very light "stuff" like dog hair will get stuck to the filter since that is where the suction goes. it's primary purpose was to keep dust out of the motor. This is a problem with many "bagless" cleaners. A bagged cleaner keeps all dirt and hair away from filters by utilizing the bag as primary filter. If you have alot of dog hair then this may have been the incorrect choice of a vac. all you can do is brush off the filter each time you use the vac. it will still pick up o.k. even when there is hair on the filter unless you leave it on day after day.
Jun 14, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
No suction
Hi elora,
I live in a house with three shedding cats. I also have the same vacuum. About twice a year, I have to getinto the area of the vacuum where the motor is. There is a little pring loaded vavle that sometimes gets hair in it. You may need to go there to get the little valve cleaned out.
Oct 31, 2007 | Bissell 3590 CleanView Bagless Upright...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
130 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
