Question about Vacuums
I bought a vacuum for my daughter and it worked a week before the switch went on it. how can i get a switch C2006B 31cx E306773 these are all of the numbers that are on it. Like I said she used it less then one week and it has sat since then. THank you Klynn1979 Kay
    President:
  • 1,673 Answers
If this was new when you bought it, it should have a years warranty on it. Otherwise you will have to find a repair shop that will order it for you.
Posted on Apr 15, 2008
I am trying to find out the size of the filter. The model is C 2006P. It also does not have a brand name, only a D on the side. It takes a cyclone shaped filter
Mellisa, searched the net, very little info. suggest you take vac/filter with you and stop by a vac/repair shop who will be able to see if it matches other models and can set you up with replacement filter.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 27, 2016 | Filter Vacuums
Hoover u5140 900 doesnt start....its dead
These are known for switches going bad. The new switches are much better. They get hot and stay in either the on or off position when they go bad. Remove the top cover to reveal the back of the switch. Not difficult to change. This is your part:
http://www.vacuummedic.com/product.php?id=395
Good Luck!
Vac Dr.
Oct 07, 2012 | Hoover Tempo Widepath Upright Vacuum,...
I have a DC25 that I just bought in Dec 10. The last few times I vacuumed the carpet, the beater bar worked on and off. Now it does not move at all. I took off the beater bar to see if there were any...
This is a good quality machine which I am sure wil last a long time in answer to your question make sure that the setting is set for carpet and not just flooring ..the head needs to be flat on the floor for the beater to work .I am assuming that this is quite new and therefore no wear to belts, also check no hair is caught around the bar sticking it, I have two daughters and this often happens to me ,,Good Luck.
Feb 27, 2011 | Dyson DC25 All Floors Bagless Upright...
New Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Vacuum shut off while in use. almost new. now it won't turn on. other outlets work so not a breaker.
Not sure if this will help, but this is how my problems began, then I noticed the handle getting very warm. This went on for a few weeks (used the vacuum maybe 4 times).
Eventually, the handle got hotter and hotter, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Mar 12, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Vacuum filter
We bought one a couple years ago too, no filters. Now, WalMart carries replacement filters for other vacuums that will fit. Go back to WalMart and pick up the Durabrand CF2006 - it's in an orange box, works like a champ, I think it was around $5. We bought a couple. Great vacuum.
Aug 26, 2008 | Vacuums
Electrolux Oxygen Remote Control Z5654 Vacuum Cleaner
Check your hose for obstruction. That might be the problem. If not, you will probably need service.
Jan 02, 2008 | Electrolux Z5935 Bagged Canister Vacuum
Kirby Heritage II not starting
take the cover off to get to the wiring and check the brushes - that is where the clear-insulated black & green wires terminate at the motor sides under the plastic caps
Nov 20, 2007 | Kirby Heritage II Vacuum
Vacuums Logo
93 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
