Question about Xerox Phaser 7300DN Laser Printer
Phaser 7300 problems
Hi read your post on the 7300 sensor flags, I have 3 issues with my 7300 I want to solve, Here is what I posted.
http://www.fixya.com/support/t286253-toner_sensor_board#
tryit's suggestions are very helpful, I would like to understand how the sensors actually work, I used the method described below to at least keep it going until I arrive at a solution. I have been quoted $600 for the top cover and sensors and $300 to install. Is this a wide spread problem or does it just show up on older high page count 7300s?
Thanks
Craig
Art Academy of Cincinnati
My spit and bailing wire fix
"This may or may not help but I was able to greatly reduce the number of times the error occurs by taping a small piece of very soft foam rubber above the sensor flag with double sided tape. This will do for now until I can learn more about the repair.
got to mention there is a tech note on this I heard and it talks about a "bounce" of the flag sensor and a time out causing the problem."
The questions I want to work on are
#1 the sensor flag problem
#2 I want to disable the %#$@*! ability to print menus from the front panel. I have this issue with students coming up to the printer, having some problem or being impatient and not choosing the right page setup/paper tray/paper then hitting buttons.
The blasted thing defaults to having the Menu highlighted, if they hit OK it goes to Printable Pages Menu. Then they hit OK and it asks to put paper in the manual feed tray, I find it this way all the time, sometimes I can get it to cancel, sometimes not.
  • 1 more comment
  • vudutu Apr 14, 2008
    Thanks Iqbal, I saw the service bulletin from Xerox, it described the problem and said the fix was to replace the whole top assembly. I will be the first to agree though there may be a cheaper way. I have also heard to try remove the flag and sand the pivot shaft and smooth to provide free movement. I may order the flags and polish the shaft, Thanks for the diagram link
  • vudutu Apr 15, 2008
    Thanks Iqbal,
    I ordered the sensor flag kit from Xerox, $31, Any ideas on the second question? I think for now I am going to print a BIGGER sign on the printer and a stack of 8.5*11 paper in the MFTray. I don't see a button to rate, hit accept?
    I have seen thos links maklean, any ideas on the second half of the question?
  • 655 Answers
Hmm i think it will be better to re-place the sensor as it cost only upto 20$.
Anyways you should have a look on this link. Here is a detail diagram with full specification.
I think it will help you.
Thanks
Iqbal
Posted on Apr 14, 2008
  • Iqbal Husain
    Iqbal Husain Apr 15, 2008
    Thanks vudutu,
    I know you are a tech-person and you will do very well.
    I am till waiting your rating for my solution as fixya.
    With great hope.
    Iqbal
  • Iqbal Husain
    Iqbal Husain Apr 16, 2008
    vudutu,
    I don't think there may be any option to disable menu. You can block it making disable the connection from button on PVC (just putting a solo tape), but I don't like this type of solution because in this case to enable the button you have to make connection again.
    Anyway if you will hit Accept button against my solution then my solution will get fixya rating.
    Thanks vudutu for your nice feed-back.
    Iqbal
    Genius:
  • 1,665 Answers
The Phaser 7300 is being shut down because of a wrong signal that the transfer unit is at the end of its life. The transfer unit is a month old on a unit that has medium usage. It should not be at the end...
I think you might have a Spring missing for the Waste Toner Full Sensor. Truthfully, it is really hard to describe in a few sentences.
It belongs in the frame wall under near where you have the white waste toner section of the Transfer Belt. This spring pushes a flag up that hits the Paper Entrance Sensor (yes, near the bypass tray)
The PN for the spring is 116-2050-00
Whit
Item, Inc.
May 20, 2010 | Xerox Phaser 7300DN Laser Printer
I have a phaser 7300 that asks for a transfer unit about every 3 weeks. It prints good until it asks for unit and then it will not print until I install a new one. I am ready to install the 4th unit but...
I think you might have a Spring missing for the Waste Toner Full Sensor. The machine tolerates the sensor status for 2K pages and then shuts it down.
Truthfully, it is really hard to describe in a few sentences. It belongs in the frame wall under near where you have the white waste toner section of the Transfer Belt. This spring pushes a flag up that hits the Paper Entrance Sensor (yes, near the bypass tray)
The PN for the spring is 116-2050-00.
Whit
Item, Inc.
May 21, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
The "Reseat Toner Cartridge" message keeps appearing, if I open and close the lid the message goes away and it seems to print normally.
There is a firmware issue that causes that problem.
You can download it from the Xerox.com site and upgrade your machine. The instructions on doing that upgrade are also on the site.
Go to Xerox.com. Then click Suport and Drivers, then enter 7300, then to drivers and downloads and scroll down to the firmware update.
Feb 10, 2010 | Xerox Phaser 7300DN Laser Printer
Phaser 860 screen says "paper jam - open front cover to clear"
I posted a problem with the phaser 860 paper jam. I found 2 broken sensor flags and am ordering the parts.
Mar 19, 2009 | Xerox Phaser 8400 Laser Printer
Error message: cyan imaging unit is either missing or unseated
The problem is with the top cover assembly. It could be a few things. I would first try the toner sensor flags(the magnet may not be strong enough to read properly). Also replace the toner cartidge because it's magnet may also have gotten weak. Third, I would try the Toner sensor board.
I have had this problem with many printers and normally it is just the flags because of the weak magnets.
Feb 10, 2009 | Xerox Phaser 7400/DXF Laser Printer
Phase 7300 sensor flag error
I will give you a link. Call Britt and tell him Rick suggested you call him.
If he has the part he will make you a far better deal.
Here ya go.
https://www.partsdrop.com/store/
Apr 14, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 error message...
The problem is a crazy design in the printer itself! I've now found a reliable fix for this problem which is relatively easy to carry out. You will find the details of how to do it here :
www.michelsplace
Jan 24, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
164 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
