Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother 5440 mfc printer
I have changed the ink twice and the printer says that it is empty. I have done the resetting, cleaning the heads and everything possible.
Why does it not pick up the ink? Prints only blue. says low on the other colors. Help
  • stockeybob Aug 14, 2008
    Printer reads near empty black. Have replaced ink with new cartridge, still reads near empty black. Expensive exercise if the printer is not recognising new in cartidges. Help
  • 74 Answers
1. Make sure the cartriges are name brand
2. make sure that you are placing each ink in the right slot.
3. Unplug it and press and hold the power button for like 20 seconds
4. plug it back in let it go though it's cycle,
5. try test page
Hope these tips work, if not please write back before rating me
Mitch
P.S. Don't forget to leave feedback
Posted on Apr 15, 2008
Cyan ink worked until needed to replace that empty cartridge. Now, all colors print but Cyan. I have cleaned inks, blocked eye with tape, cleaned where cartridge goes with warm water (in those holes),...
First do not use cartrigde compatible or refill because you clogged the print head,is verry sensitive.If you try to clean the print head and nothing you need to replace the print head is the only solution,after replace the print head you print all the colors.
NOTE!!! After you replace the print head use only original cartridge brother !!!!
Apr 07, 2011 | Brother MFC-230c Printer
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Copier won't copy
Some machines have a lock so the scan head doesn't get damaged, make sure that it is unlocked if your machine has this feature.
Does the color cartridge have ink as well, as some machines do not print if eather of the cartridges is empty.
Good Luck.
Feb 22, 2009 | Brother MFC-5440 Printer
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Brother MFC-5440CN Ink Status
I have the same problem.I did go to Staples store and the person told me to clean the heads of the cartridges with alcohol and the bottom injector. I tried that and it did not work.It keeps telling me the ink is low even if I put in new ones. I am going to try the alcohol solution to see if it works. If not I will return to store for an exchange.I really like the printer.
Jul 24, 2008 | Brother MFC-5440 Printer
Remove mfc 5440cn print head
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 30, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Nov 08, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
232 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
