Question about Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System
Receiver not working
I have the Yamaha model HTR5935 the unit worked until recently, I turned it on and had no sound. The lights are on but no matter what input channel I put it on- radio, dvd player or Sat tv- itdoesn't make a sound. Any ideas?
  • 4,234 Answers
The unit is most likely in protect mode. This means that the output section has been turned off to prevent further damage to the amp. Typically the problem is the output transistors failing. This will result in a parts cost of between $15-$30. Add in the local labor rate for the total repair cost.
Dan
Posted on Apr 14, 2008
Will not turn on
hi,
Nothing to do with the speaker cables , the Impedance Selector and antenna installation.
The problem is on your receiver.
First to check is the fuse on the receiver, is fuse is ok, then you need to sent in to sevice center for repair.
Hope it help.
Thks
Nov 02, 2013 | Televison & Video
I have a 70's era Yamaha Natural Sound Stereo Receiver CR-620. It just recently stopped working. It turns on, but doesn't transit sound. Can it be fixed or is it terminal?
If there is no audible physical click from the speaker output relay, after about 10 to 20 seconds, there is an electronic fault in one or both amplifier circuits, which will require repair. If you like the sound of this unit enough to pay maybe $50 give or take, get it repaired. Otherwise, you can pick a similar unit up at a thrift shop for a few dollars.
Aug 29, 2010 | Yamaha Audio Players & Recorders
I have a Sony playstation 3 that I use as my dvd player and run it through my yamaha via an HDMI cable. I also connect the Yamaha output to the TV through an HDMI cable. Until recently the playstation...
Look in the manual for which version of HDMI. If it's 1.2a, they had a problem with the boards and were repairing them. Contact Yamaha @ 1-800-292-2982 Hope this helps
Jun 11, 2010 | Yamaha RX-V863 Receiver
RX-V665 Yamaha reciever has been working great. Use it for surround sound and outside, zone two speakers. Recently started turning off during movies. I run blu-ray through receiver. When playing Star Wars...
You may find a solution by doing some of the things I have tried - see below
I recently puchased this model to replace an older Yamaha system that also had this shut-off problem. The new RX665 system has the same problem but I check the impedance setting using the instruction in the manaul anyway. The problem persists. I have check all speaker wire to make sure nothing was touching. I did find one wire touching on the center speaker but the problem persist.
Since the problem followed me when I moved and with a new amp, I am beginning to think I am have a speaker that's causing this - maybe the sub.
May 02, 2010 | Yamaha RX-V663 Receiver
I have the Yamaha HTR5935 reciever- When I turn the power on, the unit stays on for about 3 seconds and then shuts itself off. So the power is running to the unit. Any ideas?
Sounds to me like you have either your speaker wires crossed, the pos and neg are touching, or a pos is touching the case of the receiver.
Jan 24, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Display panel does not light; sound is ok
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. http://www.yamaha.com/yamahavgn/Documents/YEC/Stereo_Receivers/Manual/RX-797_e_U_p.pdf That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Jun 02, 2009 | Yamaha RX-797 Receiver
The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
May 21, 2009 | Yamaha RX-V463 Receiver
Sound turns on and off intermittantly through unit
You may have a bad protection relay or solder joint at the relay mount position. This relay prevents power supply "thumps" when the unit is first turned on, and also shuts the amp down when there is an overload problem....accordianman
May 29, 2008 | Yamaha RX-V661 Receiver
YAMAHA R-V701 MAKES BUZZING SOUND & WONT TURN ON
This could be the indication of an open resistor, or bad Capacitor in power supply. May not be visible to eye, but if you look in PS. there should be atleast one big sized cap and every PS has a bridge rectifier, this is usually 4 diodes in series, check them and see if any open, shorted
Sep 05, 2007 | Yamaha R-V701 Receiver
Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
228 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
