Question about GE WDSR2080D Top Load Washer
Water leaking From front right when washing / washer is level and we can't find a hose loose
    Sergeant:
  • 359 Answers
CHECK THE DRAIN THAT IT NOT PARTLY CLOGGED IF SO THE WATER WILL FIND IS WAY OUT WHEN IN SPIN CYCLE SEEN IT BEFORE . POUR WATER DOWN DRAIN FOR WASHER OUT OF A PITCHER MAKE SURE IT DRAINS PROPERLY , JUST A THOUGHT HIT THE PROBLEM THIS PAST WEEK DRAIN WAS CLOGGED
Posted on Nov 24, 2008
GE washers have problems w/ pressure switch malfunction
Posted on Apr 15, 2008
Whirlpool wtw7300xw2 washer leaking from bottom
check for cracked pump hose/ loose hose, leaking pump, small tube up to water level control
if the water is grey or whitish then it could have water in the gear box from a failed shaft seal
Apr 03, 2016 | Whirlpool Washing Machines
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
What code does LE stand for on Samsung front load washer
LE LE1 E9 11E Natural drain/Water leak - Low water level detected during cycle. · Check that the level of the drain hose is not lower than the base of the washing machine. Additionally check for a water leak. If no trace of water, switch off the power, reconnect and try again. · If problem persists please call the customer support team.
Mar 15, 2015 | Samsung WF218AN Front Load Washer
I HAVE A LEAK FROM RIGHT BOTTOM OF A SAMSUNG WF448AAP/XXA-000 FROMT LOAD WASHER ONLY HAPPENS DURING RINSE CYLCE
Hello Harlan;
My name is Peter. I am a retired field service appliance technician.
Your drain hose is in the back on the right hand side. This is a rubber hose. After a time the rubber may be dry rotted and leak or become partly clogged with soap residue.
Once completing the wash cycle the soapy water may have not completely drained due to a partly clogged drain hose by the time the rinse cycle is complete flooding the washer drain pan.
You do not have water in the bottom of the washer because your pump removed it all, but at a slower rate
Ok, Lets fix this ourselves:
1.) On the bottom right front of your washed is a leveling leg.
turn the leveling leg one full turn clockwise. The right front may be pitched down, causing the drain pan level on this corner to be high. Your washer through vibration may have moved slightly. This is not going to solve the problem.
2.) Pull your washing machine out so you can see the drain hose. Run some laundry on heavy load. Observe to see if your drain hose is leaking. Your hose clamps may be loose and require tightening. If it is leaking it needs to be replaced.
3.) Even if your drain hose is not leaking it must be obstructed, flooding the bottom of your unit. This is easily replaced.
The part number for your drain hose is DC97-12534D. It cast about $24.00.
Nov 24, 2014 | Samsung Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Neptune water level
ck drain hose level ..end should be 30-36 inches from floor also be sure hose fits loosely in standpipe ..possible water is siphoning out after fill up since these are low water use machines any drop in water level can cause problems
Sep 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing machine will not shut off at the right water level. What can I do to fix this problem? Water continues to overflow and I have a mess.
Water level switch has a (pressure) hose that is about the same diameter of a drinking straw.Its attached to the water level switch and may of come off. To make 100% sure its not just the pressure hose thats come off,you need to check and see first.Remove the front console so you can look and see if the hose is firmly attached.If not attach it.If it is attached,try moving up to make a better contact.Fill washer one more time on small wash setting.If the water continues past the "small" fill level drain all the water out and replace the level pressure switch.It is leaking air causing the problem.
May 25, 2008 | GE Washing Machines
GE WDSR2080D Top Load Washer Logo
219 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
