Question about True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC
True freezer gdm 35f to cold
Im trying to use this unit as a frigde for soda, water, etc.......i turned the temp dial to the 1 postion so that the unit will not freeze the beverages but it is still freezing the beverages.... is the anything i can do to fix this??????? THANK YOU!!!!!
    Scholar:
  • 149 Answers
You just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Posted on Apr 22, 2008
  • Alexander  Figueroa
    Alexander Figueroa Apr 23, 2008
    also to add to the comment e-mail me at hvac.tech7872pr@gmail.com if you have any additional questions!
True gdm35 evaporator fans not working?
change the fan motor, if the fan dont wonrk wont spread cool air
Sep 18, 2014 | True Display Refrigeration GDM-35F
Which way do I turn the temperature dial on a true 3-door reach-in stainless steel cooler?
Numbered 1-9 - one is the warmest setting, nine is the coldest. For a cooler it should be good on 5 for a freezer 7. If it doesnt work well on those settings the thermostat is usually bad.
Aug 03, 2013 | True Freezer GDM-49RF
Freezer turns back on quickly
check your temp setting. it hould be running between 0 to -5 degif it is running colder than that dajust the temp. if that does not solve the problem
replace the temperature control.
Dec 26, 2012 | True 35 cu. ft. / 991 liter Commercial...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My true cooler freezer in side fans dont turn on i run it for 15 min. the make is gdm-72f
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
Jan 27, 2011 | True 72 cu. ft. / 2039 liter Commercial...
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
I NEED A WIRING DIAGRAM FOR A TRUE FREEZERG M# T-35F
only way to get the exact one is to contact Ture at truemfg.com. They will ask for model and serial and send it to you.
Hope this helps.
Mar 16, 2010 | True 35 cu. ft. / 991 liter Commercial...
Freezer Not Fan not running!
Most all commercial freezers have some sort of fan delay/ defrost termination device. Commonly called a "Klixon" (pronounced clicks-on). It is a device that is attached to the evap. It's function is to terminate the defrost cycle when the evap reaches a certain temp, say about 50 degrees or so, to ensure there is no build up of frost/ ice on the evap. It then allows the compressor to run, and cool the evap down to a reasonable temp., say about 20 degrees, and then let the evap fan come on. It prevents overloading the compressor during a high temp condition, and it also prevents circulating warm air left from the defrost cycle. I believe this device is most likely your problem. With no air circulating, the box will no cool down.. I have seen them burn and/or slhort internally. They can come apart. too. I would look here for that problem. the True manufacturing website does not give alot of info on this piece of equipment, such as a wiring diagram but manuals are available.
Check this out and let me know how it comes out.
May 17, 2009 | True 49 cu. ft. / 1388 liter Commercial...
True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC Logo
224 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
