Question about Canon Rebel XT / EOS 350D Digital Camera
Can't Shoot At An Angle
For some reason whenever I try to shoot my XTI at an angle it won't shoot. It just beeps and it appears the lens tries to focus and that's it. I was trying to shoot some moon and stars shots with my tripod etc, but if I tilted the camera back past say 10 o'clock it just won't shoot. Any ideas?????
  • 2,039 Answers
What mode are you shooting in? If you are in almost any mode except M(anual), the camera may not be able to lock focus once you point it a relatively dark area of the sky. See if the Focus Confirmation light in the viewfinder is flashing. If it is, the shutter will not release. See page 162 in the manual for options, and page 71 for shooting Bulb exposures.
Posted on Apr 16, 2008
How can I keep the buildings in pictures from appearing to tilt inward (Nikon D5200)
this most likely is a result of your lens your using , wide angle lens usually produce this effect (its a trade off for the wide focal plane) , try switching to a telephoto , or a not as wide ratio lens this will help
Oct 29, 2015 | Nikon D5200 Digital SLR Camera with...
Tip
My camera has spots in the picture
The spots are caused by the flash being SO close to the lens. Anyobject that can reflect the flash reflects it right back at the camera.
This is an image problem with most point and shoot digitals. Watch forreflective surfaces and stand at an angle to them. Turn on more lightsin the room before using flash. Most indoor pictures start way too dark.
Stand at a slight angle to the image orperson you are photographing - don't shoot straight on. (I kneel downand shoot up - makes a good shot too.)
If you are shooting toward the sun lit side of an image, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
A professional photographer has the flash way away from the lens for a reason...
on Mar 31, 2010 | Cameras
I just bought a Rokinon 10mm T3.1 Ultra Wide Angle Lens for my Sony Nex 7. I am getting an error message when attached that says Lens not recognized please attach correctly.
Samyang 10mm 2 8 Wide Angle Lens Unboxing Impressions Sample Pictures
Regarding a 3rd party lens it always have some problem. Manually pictures can be taken , if completely not supported. Check the video and find similarities. Like keep F- 22 IN LENS , ( or the highest FNumber ) .. turn on manual controls.. then shoot.. check if this helps and inform
Jun 23, 2015 | Rokinon Cameras
Hello,when i use it at wide end (17mm) the AF on a landscape (infinity) is very unstable. 50% of pictures are out of focus.This can be seen also on the distance scale: at one shoot it is at 3m , at second...
With landscape photography, especially with a wide angle lens, there is often very little visual contrast for the AF to lock onto. Try using MF for these shots.
Oct 01, 2017 | Canon EF-S 17-55 f/2.8 IS USM Lens
Is the Wide angle converter (Nikon Wc-E68) compatible with the D3000?
No. The converter is intended for certain point&shoot cameras. It is designed to fit in front of the much smaller lenses. The D3000 has interchangeable lenses, so you can simply remove whatever lens you have on it and attach a wide-angle lens.
Feb 14, 2011 | Nikon WC-E68 0.70x Lens Converter
Have faded black corners on images (intermittent issue, doesn't happen with every photo shot). I'm sure it's user error, but I can't figure it out.
Common problem and yes no to user error. You didn't say what lens you were using but I'm going to guess it's an 18mm on the wide end AND maybe you have a UV filter on it to protect the front lens element. What you are experiencing is what is called vignette. I hope my spelling was correct. What causes this is the extreme wide angle view of the lens, actually capable of seeing the edge of the lens barrel, there is another little problem that messes with your brain, you can't see this happening until after the picture is on the computer or you have enlarged it on the camera view screen and then zoomed in on the corner(s). The reason behind this is what you see in the viewfinder is only about 94% of the total image you will get on the view screen (LCD) or see on the computer monitor. So what can you do about this? There are a few things some you won't like. While taking a full wide angle shot remove the protective or polarization filter and shoot a "Naked" lens (correct for contrast in post processing) Stop the lens down to say F8 or F11 which will use more of the center of the lens but still give you the wide angle however you don't get something for nothing. You will most likely trade off shutter speed and need to use a tripod. Make sure if you are using a VR type lens that you shut the "Vibration Reduction" off when the camera is mounted to a tripod or you'll have some more issues. What I do at the 18mm end is shoot it without a filter at F8 or F11 and in post processing crop out the corners by enlarging the photo/print slightly. I call this shooting loose relying on the 6% I don't see in the viewfinder and shoot the scene knowing I'm going to "zoom crop" in Photoshop. Hope this was a help Happy New Year
Dec 31, 2010 | Nikon D50 Digital Camera
I have a Sony DSC T-90 12.1 megapixel. I often
The vertical line can be caused by a very bright object in the image like a lamp or a silver surface reflecting the flash.
The spots are caused by the flash being SO close to the lens. Any object that can reflect the flash reflects it right back at the camera. This is an image problem with most point and shoot digitals. Watch for reflective surfaces and stand at an angle to them. Turn on more lights in the room before using flash. Stand at a slight angle to the image or person you are photographing - don't shoot straight on. (I kneel down and shoot up - makes a good shot too.)
If you are shooting toward the sun, shield the lens from direct sunlight with your hand (Keep your hand out of the picture!)
Mar 31, 2010 | Sony Cybershot DSC-T77 Digital Camera
Wide angle cap vs wide angle lens
The cap is a plastic disk, usually black or silver, that snaps on at the end of the lens to keep the lens clean. Some lenses have two caps, one for each end when not attached to the camera.
Some cameras don't use a "loose" cap; those cameras generally retract the lens into the camera body and "close" a door in front of the lens.
Many, if not most, camera users do not use a cap (my guess).
The wide angle lens is generally an "optional" lens that can be used for group or scenery pictures when you want to shoot a "wide" picture. A "normal" lens is generally around 50mm (plus / minus 5mm). A wide lens is anywhere from 17mm to 24mm (or so).
I recommend obtaining a wide lens... with a cap.
Hope this helps!
Sep 10, 2009 | Casio Exilim EX-Z57 Digital Camera
Autofocus gives erratic results
Are you using this indoors, in low light perhaps? This would be the most common reason for this happening. The only way to get around that is to use a "faster" lens, such as f2.8 / f1.8 / f1.4 etc.
If not, try cleaning the lens and camea contacts with a plastic eraser, make sure no debris falls in the camera body (hold upside down for this).
Jun 02, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Pictures come out very yellow/orange
Remove the lens hood to avoid unwanted bottom shadows.
May 10, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
