Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi ultravision 50v500
I had to change my digital cable box. it appears to be an identical motorola box (comcast). when they reset the signal the vid 1 will not come on. games and dvds are vid 2 - 4. they work. i can watch my tv on ant a. any ideas on why i cannot watch tv on vid 1. vid 1 is where the hd channels are best viewed. no channels are coming up on vid 1 at this time, it is a black screen with no sound.
  • iowamandy Aug 04, 2008
    the power light will come on but there is no picture or sound
    Genius:
  • 1,224 Answers
There should be 3 sets of video rca jacks on tv or receiver they might have put them on the wrong rca jack in which they just need to be moved over
usually the 3rd set of rca jacks are component jacks not for tv or video but for low output signals say like cameras and only one set of rca's can be used at a time svg on one of them rca's will over power the vid's. so have no picture
Posted on May 10, 2008
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Cannot get menu for A/V mode to shut off Closed Caption
Try first disconnecting cable from tv and unplugging power cord from power for ten minutes
Jul 24, 2008 | Hitachi 42HDF52 Television
The tv is showing a double image and I cannot get the color right! Model number 50v500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to upgrade to the high definition cable box---but first try this. Hook the cable from the wall directly to the tv and autoprogram it. If Comcast is anything like charter they transmit the local Hd channels in a format that digital tuner will pick them up. Just channel up/down and check out the channels with -1 and -2's behind them. Depending on where you are----your local channels will usually show up wherever they normally do but with a -1 behind it.
EX: local Fox channel on 47---autoprogram and check 47-1
If this is enough HD for you then get a two way spitter and hook your box back up and keep using the RCA (composite) cables for the best it can produce.
hope this will help..
May 21, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Splitter side of Comcast cable signal unusable. Converter box OK
DTR's are available everywhere. You can also go online and purchase one if your local stores do not have. Also, keep in mind that the splitter you use must comply with the signals unless you use the Video output of DTR.
Jul 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Jun 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Weak signal or channel not available
Digital signal requires all connections to be snug.. double check them. Also if you have splitters in the line, make sure that they are rated for digital, good quality (you get what you pay for) and the mhz is rated for 2 gig or better... if probems persist, you can install a digital cable signal booster... Amazon sells a motorola model that will boost the signal 12x. Got one this week and works great...
Good luck on this, let me know how it goes..
KEN
Apr 03, 2009 | Hitachi 50VS69 50" Projection HDTV
How do I set up model 50v500 hitachi tv to receive hd
You have to have an hd cable box it is different from your run of the mill digital cable box. Most people rent them from their cable provider. This will enable you to get HD channels through them
Apr 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi Ultravision LCD Rear Projection
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
Jun 24, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
128 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
