Question about Toshiba Satellite A135-S2276 Notebook
Keyboard function Hi, When I type . I get .9 When I type , I get , 8, so the keys are typing two thing at once. A period and the number 9 at the same time. Any suggestions??? Thanx
  • Toshiba Master
  • 13,433 Answers
The keyboard is broken and needs to be replaced, try booting into dos mode and see if the problem persists
you can get a dosboot disk / cd from www.bootdisk.com
if the problem doesnt happen in dos then there is most likely a virus in you laptop. if the problem persists in the dos then the keyboard needs to be replaced.
Posted on Apr 15, 2008
  • Ekse Apr 15, 2008
    also try a external keyboard on the device.
This afternoon my laptop was working fine, then the keyboard started messing up, when I pressed any letter it came up with 4 other letters. Then i pressed '9' once and it continuously typed 9 until I
First thing I would ask is this. Was anything spilled on the key board? I had a situation similar to this and I found that my son spilled a Sprite and wiped it up but didn't tell me about it. One way to check this is to hook an aftermarket keyboard that runs off your USB2 port and see if the keys work correctly that way. If they do, I would suspect that something was spilled into your laptop keyboard.
Feb 06, 2013 | Computers & Internet
Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
Hi.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
If there is anything else please post back.
Good luck.
Jun 07, 2011 | Computers & Internet
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
When I type 0 9 numbers are coming up instead of letters problem:
If you had specified exactly what computer you have I could have give you exact instructions ;) Here are general instructions that should help with this problem.
Look around your keyboard, see if you can find a key marked "Num LK". If the Num LK text is the same colour as your other keys, just press it once. Try typing, see if that helped.
If the Num LK text is blue, Look around your keyboard, see if you can find a key marked "Fn". Hold the Fn key pressed while pressing the Num LK key once. Try typing, see if that helped.
Good luck ;)
Feb 02, 2011 | Acer Computers & Internet
I type j and it comes out 1. can't fix.
Try this.
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times. does it help?
I think your numlock might be stuck on and your keyboard "num lock" key isnt working
Jan 04, 2011 | Computers & Internet
Keyboard keys share functions. Right shift key inserts a z and then shifts. z key does the same thing . Left shift key tabs and then shifts. 9 key and = key both give =9. Other keys also share...
1. try to do system restore first from the time system was working fine. reboot system. if fails.
2. update your anti virus then run a full system scan. reboot system. if fails.
3. update the bios. download the latest bios for your system from the dell support drivers and download section. reboot system. if fails.
4. reseat the keyboard cable. if fails.
5. reinstall the OS. if fails
6. replace keyboard.
Oct 25, 2009 | Dell Inspiron 2200 Notebook
WINDOWS XP TABLET EDITION WILL NOT TURN OFF & Keyboard Glitch
Hi Denniskeys,
I'm not 100% sure, but I think that the numberpad function in active on your keyboard while your trying to type. Perhaps you could try disactivating the number pad by using (FN+F11) keys. If its tuned on, you will see a small green light under the F11 key. Once its turned off, that light will also turn off.
Try typing ofter turning it off and see what happens.
Hope this helps.
Dec 29, 2008 | Toshiba Portege M700-S7044X Notebook
Keyboard probs advent 9115 laptop
Sounds like your num lock has been toggled on by mistake. Look for a key that says NmLK. It will be in the same color blue. That key may also be the scroll lock key(ScrLk) that should solve your problem.
Thanks
Todd
www.LaptopGuy.com
Apr 23, 2008 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
