Question about Canon CLC 2400 Color Copier
My canon clc 2400 i9s dropin toner or starter
Hi. my color copier is dropin toner o starter from the developer assembly, i dont know what is happening. i need help, i contact to five or six technician and the problem continue, thanks.
  • luis alonso Jun 13, 2008
    Thanks to your answer... look...
    the developer is dropped, its appear in the transfer belt and when the drop is excesive is dropped to the floor (too much), when i print, i have a black fog in 100% on the letter or tabloid.
    i change the developer assembly, with new developer too, and the problem persist.
    thanks.
  • 67 Answers
I---YOUR HOPPER COULD BE BAD, THE HOPPER DRIVE BELT COULD BE WORN OUT, IF ITS THE DEVELPOER THEN YOU NEED TO CHANGE YOUR DEVELOPING ASSY. YOU NEED TO BE MORE SPECIFIC WHERE IS THE TONER GOING ON THE TRANSFER ASSY. OR THE GROUND HOW ABOUT YOUR QUALITY
Posted on Jun 12, 2008
  • khamral BAKSH Jun 13, 2008
    your hopper is damage that is the one that is dropping toner, and the fog can be caused by a bad cleaning assy. that is a drumcleaning assy.
IAM GETTING A CODE ON CANON CLC 1150 EO20 &E0181
This is an error for the Drum units. The E020 is for toner concentration, the " 01 " is for Magenta and the " 81 " is for the concentration in the developer unit for the window sampling is below 70. Best thing to do is replace the Magenta Starter and do an initialization procedure in Service Mode. Better left to a Tech.
Jun 20, 2011 | Canon CLC 1150 Color Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
CODE EO20400 COMES UP WHEN TRYING TO MAKE COPIES
toner clogging between sub hopper and developing assembly
May 20, 2010 | Canon CLC 1150 Color Copier
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
Solution for error code e020004
The toner concentration sensor is faulty.
The developer inside the developing assembly is not stirred properly.
The sensor is subjected to stray light (no cover, front cover open).
The photosensitive drum has deteriorated.
Apr 23, 2009 | Canon CLC 1150 Color Copier
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Jan 29, 2008 | Canon CLC 1150 Color Copier
CLC 1180 with error E020 with sub 124
first check this site for the error codes.
clik here
The error code E020 refers to a density problem with one of the Drum Units.
ur hopper motor has jammed and it is not allowing the toner to go to the developer just open the hopper motor and put it into the developer or remove the connecter attacted to the developer. it will work . there is a gear actually on the motor which breaks.
So the only sol. is to replace, if it is under warranty caontact the customer care..
Goodluck,
Dont forget to rate me as fixya..
Canon color laser copier
E020 is a toner feed problem to the developer. First, check for broken gears or missing teeth on all the developers. That is usually the cause.
Nov 05, 2007 | Canon CLC 1000 Color Copier
Canon CLC 2400 Color Copier Logo
103 people viewed this question
old marine
old marine
Corne Viljoen
