Question about Honeywell Heating & Cooling
My thermostat T8400c 1024 Won't turn on the screen is just blank
4 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: digital thermostat not working
Can you saY, Batteries!
Posted on Sep 15, 2008
mpcheeseman1
  • 1400 Answers
SOURCE: I have a Honeywell T8400C
Hello
Try taking the batteries out for 5 min,or disconnect power for 5min.
To clear it out.
Then re input all your times days and temps,
Is t stat in a cold location near a door or window?this could also override your settings,most progrmamble stats will go into override at 58.f im guessing this is not your problem.
If it continues after you reset,i would consider a new thermostat.
Hope this helps.
Posted on Jan 28, 2010
heatman101
  • 43501 Answers
SOURCE: changed honeywell T8400C 1024 to
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Posted on Jun 12, 2011
The display on my thermostat T8400C 1024 isn't working. Everything else works but the heat and the flame is not igniting either. Please help.
Sounds like a manual limit needs to be reset (thermal disc). Generally the manual limits are around the exhaust - backdraft, or burner assembly - flame rollout.
Feb 15, 2014 | Honeywell Heating & Cooling
I HAVE A HONEYWELL MANUAL THERMOSTAT NO BATTERIES ALL IT HAS ON THE BACK IS T8400C 1099 (2) 0710 1B HELP, IT DOES NOT SHOW ANY THING THE SCREEN IS BLANK
This model of Honeywell thermostat uses the 24v from the unit to power it. One of three things must have happened.
1. You have lost power to the furnace, therefore no power to thermostat.
2. You only have 4 wires hooked up on the thermostat and not 5. A lot of older homes had just 4 wire running to the thermostat, which will not work for this thermostat. You should have a wire connected to the (C) or (B) terminal on the thermostat, which ever one they have, I can't remember off hand. These are the Common terminals. They have to have the common from the furnace 24v power to operate.
3. Faulty thermostat, which will obviously have to be replaced.
Hope this helps and gets you to cooler days!
Jun 28, 2012 | Honeywell Heating & Cooling
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
Red to R
White to W
Green to G
Yellow to Y
Blue to C
heatman101
Jun 12, 2011 | Heating & Cooling
My honeywell t8400c also went blank. I can not find a battery anywhere and if plugs into the wall to get electricity. Everything works but the digital read out. Any suggestions
it should take a battery and it has wires coming from the unit for power as well the stat splits open from the wall leaving some of it mounted on the wall the batteries are in the part that pulls off the wall and the wires are on the part that stays on the wall the power wire is red on r terminal
Sep 23, 2010 | Honeywell Electronic Programmable...
I have a Honeywell T8400C 1024 thermostat. the last two nights, our heat continues to run without shutting off at the pre-set temperature. We have woken up to 81 degrees in our house. What is the...
Hello
To clear it out.
Hope this helps.
Jan 28, 2010 | Heating & Cooling
Honeywell T8400c thermostat went blank. central heating is not working although warm water is alright. any idea?
I would check the batteries in the thermostat. If the batteries are okay then you might have a blown fuse in the furnace or the furnace lost power check the breaker.
Jan 21, 2010 | Heating & Cooling
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
172 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
