Question about Danby Silhouette DWC512BL Wine Cooler
Danby silhouette wine fridge
We get E4 on the lower compartment and I can not get it to change.
The run light does not come on.
Today the inside of the fridge is 90 degrees.
This has happened before and then it seems to reset itself and run OK.
What is the problem and how do I fix?
    Sergeant:
    Champion:
  • 317 Answers
Sounds like there is a problem with the freon system. Either it is mis routed, or it is low on freon. Find a good refrigerator repair man, an ask him to heck if your system has sufficent freon, and if the system is functioning correctly.
Posted on Apr 14, 2008
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 14, 2008
    You might unpluging it for a couple of minutes result to reset the error display.
    If persist have an experienced person to check if there is cooling liquid leakage.
We just received our Danby 35 bottle wine fridge with digital temperature display, and cannot turn off the light.
I found the users manual for your Danby! You have erroneously called it a 35 bottle unit, when in fact it is a 50 bottle unit. Click HERE for you manual. In the manual, it says you can use the light manually or automatically. There appears to be a switch on the bottom of the unit. I suggest the manufacturers manual for it holds a great deal of information that can be of assistance in the future, as this is a discontinued model
Good Luck, and I hope this is the answer you are seeking. Please rate and comment, Thank You Joe
Sep 07, 2011 | Danby Silhouette DWC512BL Wine Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
Code E4 on dandy wine cooler mod # dwc283bls
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Feb 18, 2011 | Danby DWC283BLS Wine Cooler
Danby Silhouette DWC513BLS lower back fan noise.
Called Danby customer service. Requested repleacement part of lower fan unit. Located at bottom right on back of unit. Part was $6.68 plus shipping. Less than $10 total. At my door in 3 days. Plug and play piece that was easy to change. A very cheap fix and I hate to think what a service call would have been. Danby ph # is 800-263-2629.,
Dec 08, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Nov 27, 2008 | Danby Silhouette DWC512BL Wine Cooler
E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Nov 17, 2008 | Refrigerators
Wine cooler noise
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Danby Silhouette DWC512BL Wine Cooler Logo
547 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
