-   Copier give the paper jam symbol, but no jam is present.-   tim5848
Mar 06, 2009
-   I accidently turned off copier in the middle of a copy job. Ever since then, the "paper jam" (8 with ziggy sign) light is lit. It will turn on and warm up to start a job but just as the back glass lights up, the ziggy emblem lights up. -   arenacopy
Jan 07, 2009
-   my copiwe shows a vertical 8 with a zigzag every since I opened it to check the toner. It will not copy anything, HELP-   ralee2006
Jul 20, 2008
-   Copier shows symbol 8 with a vertical zigzag line in red beside the number window. Copier does not work anymore.
-   Guest
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or...
(More)
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or someone who can clean it properly. Do you have in-home service?
i cannot fax from c3200-c1. every time i try i get paperoutput that looks like pcl language - out of...
(More)
i cannot fax from c3200-c1. every time i try i get paperoutput that looks like pcl language - out of the printer. manual fax from device works
