Question about Acer Aspire 3680 Laptop
S-video connector I am trying to access a remote DVD burner using my s-video connector, but it dosn't work. How can I enable the s-video port? Thankyou
    Genius:
  • 1,027 Answers
Usually through the FN + F? key to toggle internal external or both
Posted on Apr 16, 2008
DVD SATA not boot up
is it possible that cable came unplugged. If it is a new drive on a older system, it is possible that the sata port has been disabled in bios. Some oems only enable the ports that they are using.
Jun 18, 2012 | LG Electronics GH24NS90B 24x DVD Burner
BDR206bk/1 Bluray Burner?
It shouldnt need a driver to boot from it on a modern system, as far as i know... although to be honest never tried an install via a blueray drive.
I assume you have already set the boot sequence so this drive should boot first, from within the BIOS.
You can access the BIOS usually by pressing repeatedly either the F2, F10 or delete key, depending on the system, as soon as you power on the system. within there, often under "advanced settings", look for boot sequence... and make sure this drive is listed first... then save changes and exit...
I know there are some issues depending on which sata port u are using on the mainboard... try changing the cable to another sata port. if the sata port is an ODD port, it is often only enabled when ACHI is also enabled from within the BIOS. so, id try changing the sata port the drive is connected to...
a couple of things to try first...
hope this info helps.
May 19, 2012 | Pioneer BDR205 Bluray Burner
What is a USB tv box and what does it do?
This is Teac's description of what this unit can do.
TEAC's TV Tuner enables video and regular Television viewing on a notebook or desktop PC. Simply, turn your notebook PC into a portable TV! TEAC's USB TV Tuner is the smallest video capture USB2 device available today. The tuner allows you to watch, capture, and record your favorite TV/CATV, VCR, DVD or Video Camcorder on your PC, then burn them to VCD, SVCD or DVD disc with your CD or DVD Burner. Simply connect your analog cable or antenna to TEAC's TV Tuner, grab the remote and you are all set! The Tuner can be used to record video files or TV programs in DVD quality. With the bundled MPEG-1/MPEG-2 Encode software, recording a favorite video or TV program can be easily done. MPEG editor can be used to edit video files, which can then be burned into VCD, SVCD, DVD by using CD/DVD Maker software. The Tuner can support multiple video inputs, including S-Video, Composite Video, Coaxial/Antenna TV connector. It is a DVD quality TV/Video recorder.
Dec 08, 2009 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Gear Head Lightscribe 24x DVD+/-R Triple Format SATA
Your original CDROM drive is likely an IDE interface (large rectangular connector), where as the new one is a SATA interface (small narrow connector). If your original is an IDE, the simplest solution is to return the SATA and purchase an IDE DVD.
Oct 26, 2009 | Gear Head 8XDVDEXT DVD External Slim...
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Sony WEGA
If your remote has a wega gate button press that and it will allow you to add and edit the inputs.
Apr 17, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
S-Video connector
take out vista basic pit ib xppro will i workt
Apr 11, 2008 | Acer Aspire 3680 Laptop
DVD burning
It's not a DVD burner, it's a dvd player and a cd burner.
Apr 10, 2008 | Acer Aspire 3680 Laptop
DVD burn
Chances are that your laptop has a CD burner and a DVD rom which only reads DVD's but will burn regular CDs
Hope this helps
DVD Burner
Even if the burner is very quick, I suggest that you don't try and use it at it's maximum speed, but the lowest. Try 4x, and if it gives you DVDs that work, then you can start working upwards if 4x is too slow for you, untill you find the fastest speed that gives you working DVDs. Also shut down all other programs while burning, especialy heavy ones. If this is not it, and you keep having problems, add a comment. Good luck!
Jun 20, 2006 | Magic INCDRW4048 MagicSpin (INCDRW4048)...
Acer Aspire 3680 Laptop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
