-   I got as a gift but don't have the instructions or the recipe. If anyone could e-mail to me it would be greatly appreciated. With so may of us having the same problem don't you think that they (manufacturer) would want to help? Thanks, Cindy
-   cindy9999
Jul 17, 2008
-   My wife lost our manual & we are planning on entertaining soon. We love our machine. Could you please e-mail one to me at sf5638@comcast.net? Thank you!-   sf5638
Jun 04, 2008
-   I have emailed and called them and still can't get any response from them. Any chance anyone has the book and can scan it in and email it?
-   fishmom23
I don't have a flatbed scanner to scan it, but here are the operating instructions (at least for the 5201).
1. Place canister in freezer for 8 hours (must be frozen solid-so that you can't hear liquid in canister sloshing around)
2. Prepare your ingredients ahead, and chill them for best results.
3. Take canister out of freezer and place on motor base. Use canister immediately after removing from freezer, as it will begin to thaw once placed at room temp.
4. Place the paddle inside container. Be sure the tould side of the paddle faces up.
5. Lock the lid (the clear plastic piece that fits over the container)onto motor base. The tabs on the bottom of the lid should line up with the indentations in the motor base. This ensures that the lid is locked in place. When fitting the lid onto the base, the stir paddle should "fit" into the lid.
6. Turn the On/Off dial to the right (on position).IT IS IMPORTANT THAT YOU TURN THE UNIT ON BEFORE POURING IN THE MIXTURE. THE CANISTER ROTATES WHILE THE STIR PADDLE REMAINS STATIONARY.
7. Slowly pour the mixture in the top opening of the lid. It is at this time that you place the top on the clear-vue lid and leave the machine on for about 5-30 minutes (time varies, depending on the coldness of ingredients and canister, and desired consitency) If making ice cream, your result should be a soft, custard-like ice cream
8. When the frozen dessert is ready, make sure the unit is off. Remove the lid and the mixture from the bowl with a plastic spoon or scoop. NEVER USE METAL INSTRUMENTS IN THE CANISTER.
9. Ice cream will be custard-like. If you prefer hard ice cream, place in freezer in air tight container and allow to set until it reaches your desired hardness. Don't put the ice cream in the canister in your freezer for more than 30 minutes, as the ice cream will freeze solid to the container and possibly damage it.
Hope this helps... If you need something else, let me know. I will try to check back soon.
I received a Buffalo Blizzard Maker for Mothers day and I have used it one time and now it does not...
(More)
I received a Buffalo Blizzard Maker for Mothers day and I have used it one time and now it does not work. What do I do?
Have usually been able to turn off maker immediately when it stops. However, this time I was unaware...
(More)
Have usually been able to turn off maker immediately when it stops. However, this time I was unaware it had stopped and was not able to immediately turn off. Now it does not turn on. I suspect motor burn out. What to do? Buy new motor? Have to buy new maker?
2-3 minutes after I pour the solution into the canister, a thin film develops on the bottom of the...
(More)
2-3 minutes after I pour the solution into the canister, a thin film develops on the bottom of the canister. This causes friction with the stir paddle and the canister stops rotating. Pretty any time ice buildup occurs, instead of the stir paddle breaking up the build up, the canister just stops rotating.
