Question about Philips Audio Players & Recorders
Philips turntable af 829
When the arm comes down on the album, the turntable stops.
Specifically the turntable AF-829:
I had exactly the same problem, and fixed this succesfully.
The problem is in one of the opto-coupler combinations (LED + LDR).
There are two, both located in the mechanical part of the turntable:
1. The first is for the detection when the arm reaches the end of the record, so that it will return to base. This is a red LED with an optocoupler in a little black case. This is OK.
2. The second one is for detection that the arm has reached the beginning of the record area. You can test this by manually pulling the arm from base and moving it towards the record. Then the turntable should start to rotate. You will see it does not.
The problem is that either the LED has not got enough light-emission any more, or the LDR has become more insensitive. It's a transparent LED that radiates RED light.
I replaced the LED by a new (red) one with higher light output, and now it's working fine again.
Marcel.
Posted on Oct 01, 2008
This information is very usefull!
Thank you very much!
I have had the same problem and I have replac the 2 leds and clean the LDR's.
The only thing I didn't know was which LED I had to replace.. but I have replace the 2 LEDs because I have lots of them haha
Thank you, it was very usefull!
Kevin G.
Posted on Jun 19, 2009
The tone-arm on my turntable automatically stops too early. Is there any way to fix this?
Yes. you need to set the travel on your arm. I don't know your specific model but they are all the same concept. On the back by the pivot point there should be a small screw that you can adjust the travel before it returns.
Dec 31, 2015 | Audio Players & Recorders
Phillips AF-829
About the best thing you can try is just Google it, as you wrote above. That's about your only option. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 08, 2013 | Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
We have purchased a Philips AF 729 Mark II turntable, where can we purchase a stylus for this model and/or what would be compatible to replace this with?
The styus is a function of the cartridge, not the turntable.
For example, this one is sporting an ortofon cartridge of some sort.
http://www.classicaudio.fi/fi/index.php?mact=classicaudiocatalog,cntnt01,default,0&cntnt01what=kohde&cntnt01alias=Philips-AF-729-Mark-II&cntnt01returnid=67
While this one is somethng entirely different...
http://cgi.ebay.at/Philips-AF-729-MARK-II-hochwertige-Plattenspieler-/180639747902?pt=Plattenspieler&hash=item2a0ef7cf3e
Identify YOUR cartridge if you just want a stylus for it. Then search for that online. The mount is fairly standard if you really want a whole new cartridge. But cartridge alignment and mounting are tricky without the original jigs that usually accompany a good turntable.
Apr 20, 2011 | Philips Audio Players & Recorders
The cartridge arm does not go back to the off position.
it's a "manual" turntable so this is normal. You would need to buy an "automatic" turntable to have the arm return back when done.
Apr 22, 2010 | Technics SL-1210 Turntable
Proper cleaning of old vinyl record albums
Get yourself a nice carbon fiber brush. Purchase some record cleaner or just get some isopropyl alcohol 90% (it has less impurities). Secure the arm of the turntable so you don't scratch the record and put the record on it. Put some of the cleaning solution on the brush..not the record. Put the brush on the record and turn the platter counter clockwise to work the dirt loose. Check the brush and clean it if need be and repeat. Take the record off and clean the turntable. Flip the record over and repeat the cleaning process. That should do it. Thanks for stopping by and come back if you need more help. If you don't mind, rate my answer appropriately. Thanks.
Jan 19, 2009 | Vivitar ViviCam 10 Digital Camera
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
Aug 07, 2008 | Audio Players & Recorders
1,383 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
