Question about Bose Acoustic Wave (32022) 5-Disc CD Changer
CD player not working
The CD player on my Bose Wave Radio/CD has stopped working. I've cleaned the eye and tried holding the lid down while trying to get the system to recognize the CD. It goes through it's usual motions of starting for CD play (showing the track screen, cycling through the volume, etc), but then just keeps blinking "CD" on the screen as if it is not recognizing there is a CD in the dock at all. Any suggestions would be a lot of help, thanks in advance,
Chris
I own a bose acoustic wave which is about 8 or 9 years old now. More and more often, disks are not being read and tracks are skipped periodically on older cds and now mostly on brand new cds.  I keep the laser eye and carriage area clean and clear using canned compressed air to no avail.
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on Apr 14, 2008
    Genius:
  • 1,665 Answers
Check for belt condition. It may be worn or broken
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: how to connect my Bose Wave System to two outdoors Bose speakers?
It won't connect to externa l speakers directly but you could take the RCA output to an amplifier that drives them.
Posted on Dec 28, 2009
Why won't my bose wave radio will not recognize the 3 disc changer?
I had trouble with my wave radio. It stopped working. I took it to the Bose store and they gave me a GOOD credit towards a new one. I had the Bose Wave radio and I upgraded to the Wave CD.
Aug 10, 2014 | Bose Wave Radio
My Bose Wave radio/cd won`t play cd`s anymore. The radio works great. The cd player worked tonite, the would stick in a certain part of a song. Very intermittent. Now tries to read the disc, then says disc...
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
Aug 30, 2010 | Bose Wave Music System CD Shelf System
The cd player is not reading the discs. The read out flashes and blinks but it does not read the music off the disc.
Try removing the cover and clean glass laser eye lens with rubbing alcohol and cotton swab. If cleaning doesn't work, then laser lens circuit will need to be tested and replaced. You can use an ohmmeter to test the capacitors and circuit.
Nov 13, 2009 | Bose Wave Radio
My Bose wave radio with aux. for attaching to a CD player stopped working. I tried plugging it different places. It is an old system.
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. According to their web site, www.bose.com, they will repair most Wave radios for $100 or give you $200 credit towards the purchase of a new set. Check your options before you spend the big bucks though. A new HD radio, with better sound and a MUCH lower price, might be a better choice than repair of a problem prone Bose.
Bill B.
May 04, 2009 | Bose & Wave& Music System
I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Dec 29, 2008 | Bose Wave Radio
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
BOSe Wave Radio - Disk "not readable"
I had the same problem with the disk unreadable error and took my unit to a authorized repair dealer about 100 miles from where I live to have it fixed. It ended up costing me about $300 to have the CD unit totally replaced which is almost as much as I paid for the unit in the first place. I am like a lot of you that used the CD very little although the unit was about 3 years old. I think Bose has a problem and would like us to think it is very rare. I bought a Lifestyle surround system about 14 years ago that has a CD and have never had a problem with it so needless to say I am very disappointed in the Wave II Radio/CD system. I am fairly certain the problem will occur again, but only time will tell.
Mar 03, 2008 | Bose Wave Radio
Bose wave radio/cd often cd spins but does not play, sometines will correct if I turn unit off and on. HELP tHANKS
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Nov 27, 2007 | Bose & Wave& Music System
CD Player on my Bose Wave radio/cd just blinks CD and it appears to me that the disc is not spinning. This is the same problem that many others have already identified. I unplugged the unit and removed the battery but this did not solve the problem. I notice that there is a "platter" (part of the lid) that sandwiches the cd onto the spindle. the platter seems tight but does turn. Also, does anyone know if there is a drive belt that may have broken?
Nov 03, 2007 | Bose Wave Radio
Bose Acoustic Wave  (32022) 5-Disc CD Changer Logo
688 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
