Docutech 6100 fault code P09213 - Office Equipment & Supplies
    President:
  • 2,072 Answers
NOTE: Setting the Print Darkness to 5 will establish a baseline for the machine. After the setting is set to 5 and the fault code clears, you can then change the setting back to where you originally set it.
To set the Print Darkness to 5:
  1. Select [Printer Options] on the right side of the Touch Screen.
  2. Use the [Up] or [Down] arrow buttons on the Touch Screen to set the Print Darkness to 5.
  3. Select [Apply]. Make sure you select Apply or the machine will default back to Print Darkness 4 in the Printer Options screen.
  4. Select [Close] to close Printer Options.
  5. If available, select [Reset] in the Fault Frame.
The Fault Frame is a way the machine communicates with the user. The information the Fault Frame provides may be informational, such as explaining what features have been disabled, or provides instructions on fault clearance.
  1. Select the shaded Printer icon on the top of the Touch Screen to view the Fault Frame. The Fault Frame will open.
  2. Select [Reset], if it is available. If the Reset icon is not available, then follow the instructions in the Fault Frame instead.
Posted on Apr 14, 2008
  • Rick Kasper Apr 14, 2008
    CAUTION: Do not use warm water or cleaning solvents to remove Toner from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap.
    1. Open the left and right doors on the printer and locate the Toner area on the left side. Step-by-step instructions are attached to the panel next to the cartridge.
    2. Place a few sheets of paper or a drop cloth on the floor under the Toner Cartridge area to catch any Toner that may spill.
    3. Pull the empty cartridge out of the printer until it stops.
    4. Turn the green handle to the right (the unlatched position) to release the cartridge and lid.
    5. Remove the empty cartridge. Dispose of the cartridge as normal office waste or recycle it in accordance with local regulations.
      NOTE: For recycling information, click on the [Recycling] link under the Product Resources section on this window.
    6. Make sure the correct cartridge (MICR/non-MICR) is available to install in the printer. Remove the new cartridge from its packaging, but do not remove the paper seal.
    7. Turn the new cartridge upside down and gently shake the cartridge thoroughly to loosen the Toner.
    8. Insert the new cartridge into the printer until it stops, and then turn the green handle to the left (the latched position) to secure the lid of the cartridge.
    9. Hold the cartridge in place and pull off the paper seal.
    10. Discard the seal along with the paper or drop cloth from the floor.
    11. Close the printer doors.
    2. Clear the jammed paper or obstruction from the area.
    3. Close the printer doors.
    4. Press the [Continue] button to resume printing.
    5. Discard of any damaged sheets sent to the sample tray or purge tray.
Nokia 6100 reset protection code
You can reset your mobile using master reset code. Get the code from the site Unlocking4free.com ,and reset your Nokia 6100 from your protection code easily....
Jun 29, 2013 | Nokia 6100
Nokia 6100 unlock code
You can buy code for Nokia 6100 at Simpleunlocking.com and get the Free Unlocking instructions from Mobileunlockguide.com/nokia-6100 unlock it step by step.
Apr 25, 2012 | Nokia Cell Phones
Contact service of nokia 6100 flashing ok but ui settings not responding
Hi
Instead of flashing you can unlock your mobile by using codes.you Can get free codes from http://www.unlock-free.com/nokia/nokia-6100.html.Try this dude.
Jan 24, 2011 | Nokia 6100
What is Your Problem//Do You Need Unlock Code?
You can get the Unlock code here http://www.theunlockarena.com/nokia-6100/rs13wp9/ and Unlock the Mobile from the Network lock..
Dec 17, 2010 | Nokia 6100
Minolta 6100 displays message C0072
Are you certain it is a Minolta 6100? The only 6100 I am aware of is a Magicolor 6100 color printer. My service manual for that model lists no service code C0072.
C0072 is a common Minolta copier code which pertains to the toner add system. I had a service call the other day for C0072 and it was the toner cartridge not fully "locked" in to it's receptacle, so you can start there. Opening and closing the front door on most Minolta's will reset this code.
Good Luck
Oct 21, 2009 | Minolta Office Equipment & Supplies
Need hash code converted for hp 6100
Maybe you can google the HP 6100 battery hash code in Google.
Just click here : http://www.google.co.uk/search?hl=en&newwindow=1&q=HP+6100+hash+code&btnG=Search&meta=
Hope you can get the answer. Good luck.
Aug 17, 2009 | HP OmniBook XE3 Notebook
Xerox docutech fault code
This code has to do with the finisher. Fiind the finisher entrance sensor and clean it off with canned air. If this does not help, you may have to have the sensor replaced.
May 29, 2008 | Office Equipment & Supplies
Xerox Docutech 6100 jamming problems
E-mailed you the info. Easier to see the photos that way.
Apr 20, 2008 | Office Equipment & Supplies
Nokia 6100 security code error
IMEI: 353396/00/622606/7
MODEL: 6100
DEAR SIR SWICH ON SECURITY CODE
Aug 14, 2007 | Nokia 6100
446 people viewed this question
jasbo
jasbo
