Question about Welbilt MR755T Microwave Oven
Watt just wanted to know what the watt is
  • Welbilt Master
  • 9,098 Answers
The generic replacement magnetron for this model is rated at 500-650 watts, so it would fall into that range.
This is the closest available answer, honestly.
I appreciate your thoughtful rating of my reply.
Posted on Apr 18, 2008
What is the conversion on a light bulb that says from Hungary?
Watts are watts. 29 watts anywhere are still 29 watts. No conversion.
Feb 23, 2016 | In Microwave Ovens
I have a toshiba microwave model ER-7700 & want to know what's the power(watt)?
It should tell you on the plate/sticker of the unit. If it only gives you voltage and amperage calculate it with this formula: Just substitute your values.
P (Watts) = A (current in amps) x V (voltage)
= 15 Amps x 120 Volts
= 1800 Watts
Mar 19, 2015 | Microwave Ovens
I want to know how many watts my 2002 jvm1430bd002 microwave has...I have googled this question and have answers ranging from 700 to 1200! what gives???
Conduct what the USDA Food Safety and Inspection Service calls a "Time-to-Boil" test, which will help you estimate your microwave's wattage. Add 1 cup of water to a microwave-safe 2-cup measure. Add ice cubes and stir until the water is icy cold. Pour out the excess water, leaving just 1 cup. Place the measuring cup inside the microwave. Set the oven for four minutes on high. Watch through the glass to see when the water boils. If it takes less than two minutes, the microwave is 1,000 watts or more; if it takes 2.5 minutes, the oven has a rating of 800 watts or more; if it boils in 3 minutes, the estimated wattage is 650 to 700.
How to Find Microwave Oven Wattage eHow
Jan 08, 2015 | Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I want to know how many watts the mcm660a puts out
that unit is 700 watts. hope this helps and please dont forget to rate me Thanks ken
Jun 06, 2011 | Magic Chef MCM660A Microwave Oven
I just want to know the wattage of the MW6471G
You can find the power of this oven on the back of the oven, it is marked as Power Consumption. Whatever the number is the power of your oven. For example if the power consumption is 1200 watts then your oven is a 1200 watt oven. I hope this helps you.
Have a great day!
Carol.
Mar 03, 2011 | Samsung MW6470W/MW6471G Microwave Oven
I have a Sharp model R-3A52,old but still cooks well. How do I know how many watts it is? I need to know how many watts my oven is?
The power of the magnatron should be on the door it will be about 750 watts. You could check sharp website to get it spot on...
Apr 06, 2010 | Sharp R-1470 Microwave Oven
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
127 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
