Question about Fantom Titanium Hard Drive
External hard drive and vista
My toshiba external hard drive has a password, when connected to a computer with vista i type it in and it comes up with G:ONSPCCDH.INI are not matching with inquiry data. Make sure the INI file has the correct entry. What is the problem and the Solution?
Fixed! just select options from the password entry window and then select disable password enter the password and hey presto remove drive and reinsert and password is no longer required.
Posted on May 18, 2008
Need the latest VISTA drivers ... I'm still lookin' for them on Toshiba's site. It's a nightmare!!
Posted on May 15, 2008
Toshiba 1TB external hard drive does not show on menu
Open the file and cick save as. In the window that opens, select the external drive in the list.
or, right click the file and click copy. Open the external drive in my computer and click paste.
Mar 16, 2014 | Toshiba Computers & Internet
My notebook Lenovo no longer reads Toshiba HDDR320E04XW 320 GB USB Hard Drive which earlier functioned correctly.
1. Try to plug in the external hard drive.
2. Goto device manager
2.1. Click Start -> (Right Click on My Computer -> Left Click on Properties-> Click on the Hardware Tab -> Click on Device Manager on Windows XP
2.2 Type "Device Manager" on Start Search (Windows Vista)
2.3 Type "Device Manager" on Search Programs and Files (Windows 7)
3. Click on the Triangle next to Universal Bus Controller
roadfox.png 4. Look for a USB driver says "Unknown" Uninstall it and restart the computer with the external hard drive plugged in and you are all set
Thank you for Choosing
Jul 07, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
Hi, I haven't used this drive (Toshiba 250GB
If retreiving data is not your expertise, I suggest you take it to a local computer guy and extract it. The drive could possible be corrupt or password protected. Try best buy.
Jan 23, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
< problem identifing Sea-gate external hard drive (500 gb- no external power) > my extrenal hard drive has a odd problem : sometimes when it got connected to the vista laptop its light turn on &...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Aug 10, 2010 | Seagate FreeAgent Go 500 GB USB 20 Hard...
I have a Toshiba 250GB External Hard Drive w/ USB cable and it came with no instructions. I have used it once and went to use it, plugged it in and got the little sound on the computer and.....Nothing. How...
this might be a tab bit late....but most external hard drives do not come with too much info if any at all...go to start/my computer/you see the the external drive...right click on it (to get it ready for use) select properties..format it...yes/okay...now its ready for you to download any file you wish...you see the letter on it (the "c" drive is your primary drive)...this drive is your secondary drive....so when you are typing in word/excel and you want to save...you will save as (pick the drive letter)...same as music /video you will save as (pick the drive)...now right now you can click on the external hard drive it just open (blank page)..right click any where on the page..now pick new folder type "music" (this folder is where you can store music...now right click again on the page click new folder again rename it "photos' and can create folders for any thing you wish..when you save you just pick this drive/folder...feel free to rate the help
Dec 10, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
After i plug my western digital hde6-640g external hard drive in to my laptop that is running windows vista i get an "application not found" error.
Did the hard drive come bundled with some type of backup software? External drives often do and will try to automatically run that software when it detects the hard drive connected to the PC. If you formatted the hard drive after the software installed, that could explain why.
Aug 09, 2009 | Western Digital Computers & Internet
I have a 100g usb hard drive that i have my music on.. i was wondering how to connect it to my ps3 like a flash drive does?
here you go
Connect the hard drive to your computer using a USB cord.
Check what the "File System" type is by going to Start, Control Panel, Administrative Tools, Computer Management, Disk Manager. Select the external drive and read the "File System" type. The file system type must be "FAT32" in order for the Playstation to recognize it.
If the file system type is "NTFS", right click and select "Delete Partition" or "Delete Volume" for Vista.
then recreate the partition but do NOT format it. Make sure you assign a drive letter (for this Tutorial, we'll use h:)
If you are running Windows, format the drive by going to the command prompt (Vista, right click on command prompt in start menu and click "run as administrator")and type in "format h: /FS:FAT32" (without the quotes). You may need to substitute your drive letter. (note this might not work on XP for a large hard drive - you may have to use a third-party formatting utility like SwissKnife; however, it does work under Vista - just be sure to use the format command from the DOS prompt, not from Windows Explorer)
If you are using Mac OS X, open /Applications/Utilities/Disk Utility.app, pick the drive, and click on the 'Erase' tab. Pick 'MS-DOS (FAT)' for the file system type, and click on the 'Erase' button. This will reformat the drive in FAT-32.
Open "My Computer" and double-click on your empty external hard drive.
Create a folder system identical to that on the Playstation 3 by creating folders labelled "Picture" (not Photo), "Music", "Video" and "Game".
Load all the music you want into your music folder, all the video you want into your video folder, and all the photos you want into your picture folder. Your game folder should still be empty.
Disconnect the hard drive by clicking the green arrow in the icon list and the bottom right hand corner of the screen and select "Safely remove..."
Once your computer tells you "XXX drive can now be safely removed", unplug the hard drive from your computer.
Connect the hard drive to your Playstation 3 and use the extra space to save information and access all your extra content saved on your external hard drive
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
When I try to back up my computer files for Windows Vista using a Toshiba 320GB capacity portable external hard drive I receive the message that I need a ntfs drive. Can my external drive be converted to...
Yes, it can:
Before you begin, connect your external hard drive.
To format the drive with NTFS
1.
Log on to your computer as an administrator.
2.
Click on the Vista Orb right-click Computer, and then click Manage.
3.
Under Storage, click Disk Management.
4.
If the Initialize and Convert Disk Wizard appears, click Next. If the wizard does not appear, skip to step 8.
3e609ff.gif 5.
On the Select Disks to Initialize page, click Next.
84b8e54.gif 6.
On the Select Disks to Convert page, click Next.
330a86a.gif 7.
On the Completing the Initialize and Convert Disk Wizard page, click Finish.
a63fbd2.gif 8.
Right-click your external drive (which will probably be drive E or drive F), and then click Format.
f8f5f91.gif 9.
In the Format dialog box, type a name for your external hard drive, such as Backup Drive. Then, click OK.
7560a25.gif 10.
Click OK again.
0a517a9.gif Windows XP formats your external hard drive. Within a few minutes, your drive will be ready for you to use.
Jul 17, 2008 | Toshiba Computers & Internet
Plug and play? doubtful.
Is the drive partitioned and formatted already?
Does it work on another computer?
Is the drive powered via the usb cable, or does it have an adapter?
Do you have any networked drives on this computer?
When it is connected on your computer,
click Start
right click Computer
click Manage
double click Storage
double click Disk Management
Is it in the list of drives in the lower half of the window?
Mar 14, 2008 | Toshiba 120GB USB 2.0 Portable External...
Fantom Titanium Hard Drive Logo
345 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
