Question about Philips VR550 VHS VCR
Similar problem as you helped me solve before.
I've had this recorder for a couple of years, but I have never been able to get it to record from my set to box (Freeview). It lets me watch the channels on freeview but cannot record them. I thought at the time that because it was a new thing (DVD recorders) and they wouldn't record Digital.
main tv aerial into the freeview box,
then run a aerial lead from the freeview box into the dvd recorder and from the dvd recorder into the tv,
scart lead from the freeview box into the dvd recorder,
scart lead from the dvd recorder into the tv,
But I still have the problem of recording digital channels.
The Venturer TV has only I Scart lead socket.
  • 11 more comments
  • Bashstkid2 Apr 15, 2008
    Hi Mark,
    I've done what you said but i still can't record freeview. When I watch Freeview and then I want to watch/ record by DVD. I have to switch the 'TV/DTV button at the top of the Freeview handset. This switches to the DVD and I lose the Digital Freeview signal then.
    When I turn on the DVD it say's that it is AV2 mode.
    In the setup 'Record' I can adjust to Tuner or Scart but when I adjust to Scart the screen goes blank with alot of noise.
    On th TV I can set it to AV1 but it says 'Video In' then goes blank. I can only set it to AV2.?
    It is a Crown CDVDRW300.
  • Bashstkid2 Apr 16, 2008
    Mark,
    The SKY box is a Satellite Pay for TV system, which i don't have. On miy DVD, AV2 is already set on RGB. I'm thinking of packing it in and putting up with what I've got.
    I'm having problems again with the Video as well. You got me the Freeview recordings on that one, but last night I realised i could not record on it and watch normal TV (another program) as all the normal TV stations say 'No Signal'.
    Just found this Mark. What do you think? Sounds a UK site.
    http://forums.pcw.co.uk/thread.jspa?thre...
    Would a 'Splitter help?
    Ok I'll leave It.
  • Bashstkid2 Apr 17, 2008
    > Ok I'll leave It.
    The Splitter I mean.
    Video solved, Cable came out.
    DVD still unsolved.
    > Ok I'll leave It.
    DVD still unsolved.
  • Bashstkid2 Apr 19, 2008
    I have emailed the Crown Company via thier website with the problem and asking for a on-line Manual, but have not received an answer. Thier website looks poor and one or two links don't work. They may have gone bust?
    http://www.crowncorporation.co.uk/contac...
    I just found this on an UK site from 2006. I don't know if it's any different to what you have told me, but again it doesn't say anything about recording Freeview.
    I'm not sure that it is passing through it. To watch freeview you have to switch over from TV to freeview via the STB. To have to switch back to the DVD by pressing the button again on the STB. When you go to the DVD there is only the Terrestrial channels on it.
  • Bashstkid2 Apr 21, 2008
    Sorry, when I did what you said, everthing went blank, til I put the aerial lead back in. The freeview said 'No Signal'. On the DVD under the heading of AV2 you get a choice of DECODER, CVBS, RGB. I tried them all. On the TV (under Funtion) the choice is YUV - PC - O (All 'No Signal') - AV1 'Video In' then 'No Signal' - AV2 it works.
    Thank You Mark for trying, it is an older dvd recorder, and the firm is no longer there (I think). So I wil not bother with it anymore and just use it for recording terrestrial TV.
  • Bashstkid2 Apr 24, 2008
    Mark! (if you are still there).
    I have only just received this from Crown.
    I am sorry that it has taken a while to reply. I have been away from the office for few days. It is unlikely that you would be able to record from your STB. The reason for this is that there is a built in anti pirate software system in the DVDR and STB (Macrovision) , which detects if a program is to be copied without consent of the copyright owners. The approach from most STB manufacturers is to send out the Macrovision signal with all image information. This is then detected by the DVDR and the effect is that the recording may be blank or flash on or off. In some cases the audio is also disrupted. An earlier method was to send the Macrovision only with copyrighted programmes,which meant that your DVDR would record only non protected programmes.
    If you can watch STB channels through the DVDR but cannot record them this a clear indication that the STB is outputting Macrovision and that the DVDR has detected it.
    The only manual available for the model is the hard copy as supplied with the product.
    I hope this is of some help
    Kind regards
    Aron Cross
    Crown Corporation
    So it's the STB?
  • 472 Answers
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Posted on Apr 14, 2008
  • 5 more comments
  • Peter Thompson
    Peter Thompson Apr 15, 2008
    Hrmm interesting.
    What is the model number of the DVD Recorder?
    What should be happening is..
    The Freeview input comes in through the AV input.
    With the DVD recoder set to that AV input you should only need to press record on the DVDR to start it recording whatever is comming through the selected input. There should not be any need to change the Freeview to any other mode since it is in reality only supplying the DVDR with a signal to record.
  • Peter Thompson
    Peter Thompson Apr 16, 2008
    I was looking around for the manual and stumbled upon this.
    The last post maybe the cause of the problems from the freeview box, but I still cannot see why it could be. If you have that setting in your freeview box then try that.
    I was not aware you guys still had this type of system running in Europe, but there you go.
  • Peter Thompson
    Of you want to add a splitter, then it would have to be from the main aeiral in, one to the freeview, the other directly to the TV
    Then when you want to record on the freeview, set that in motion, then change the TV using the normal TV channels, not the VCR or Freeview. You would have to tune those stations in of course.
    But you would not be able to watch a Freeview channel and be recording another freeview channel at the same time.
    On the site they say they are, but I just cannot see how it is possible.
    Even with the freeview having an aerial out, and a scart out, it is putting the same information down both lines. It would have to have a twin tuner to do that in reality.
  • Peter Thompson
    Peter Thompson Apr 17, 2008
    I still have not been able to track down the manual for your VCR anywhere. Is it possible that one of the scart leads you are using is just the bare minimun for a scart cable.
  • Peter Thompson
    Peter Thompson Apr 19, 2008
    What currently has me is the DVDR should just record whatever it sees on whatever input is selected. The only exception to that is if the channel is scrambled, but even then you should get a warning advising that when you try and record.
    It should in all theory be able to record anything that is passing through it, and there should be no difference at all between Freeview, free to air, or any other format, as long as the DVDR is putting it through it's own input/outputs.
  • Peter Thompson
    Try this and see what happens.
    Disconnect all the cables between these 3. (except power of course)
    Then only connect these..
    Aerial to Freeview
    Scart From DVD to TV
    Eliminate the aerial from Freeview to DVD.
    Now put a DVD into the player, Select the right channel on the TV to see the DVD playing.
    OK, once you have that, stop the DVD. (leave the TV on this channel)
    Press the AV button for the DVDR until you can see the Freeview on the TV (or at least select the correct AV port the Freeview box is connected to.)
    Once you can see the Freeview, try to record it with the DVDR
    If you cannot see the freeview, check the setup menu of the Freeview box and make sure it is setup to use the Scart as the output.
  • Peter Thompson
    Peter Thompson Apr 21, 2008
    LOL, But it's annoying me now, and I am half a globe away =)
    It has to be something simple and logical.
My Panasonic DMR-EH55 recorder produces no sound anymore after 3 years of good functioning. There is no sound on TV through the scart interface and also no sound through the analog audio interface to my...
Did you get anywhere with this? I have a similar problem with a DVD/PVR from Woxter. I've tried different cables and changed many of the settings without luck. I've seen a couple of posts which suggest changing country and sound settings (to PCM), so I'll check them out before I call in a repairman to check out the circuitry around the sound output.
Sep 29, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
DVD will not recognise discs
I think that moisture has formed on the boards.
The best thing to do is to take the recorder
and put in a warm room,connect it and leave for 2-3 hours.
Then try with a disc again.
I hope i`ve helped!
Nov 29, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
Recently, i;ve been trying to record tv programs on my Panasonic DVD Video Recorder DMR-E50, as i have done so for many years. However, lately, whenever i program it to record a tv program using the timer...
Hi Leah,
Good description and good job in narrowing down the problem. The lens is the remaining common denominator.
You need to get a CD/DVD lens cleaner. It should have a disk and a bottle of cleaning solution. They are available in the electronics dept of most chain stores.
A couple drops of cleaning solution on the feathery cleaning element attached to the disk, insert the disk into the machine and hit play. Takes just a couple seconds.
Best regards
Mike
Aug 17, 2009 | Panasonic DMR-E50 DVD Recorder
Symphonic WFR205 DVD recorded but not finalized
I have similar problem. I have recorded all of my old tapes on a DVD-RW disc (lots of time spent on it) and as I wanted to finalize them - it would display an recording error. Recently I purchased a new Sony blue ray player and I realized it would play the not finalized discs. I am still looking for a solution how to record these memories on a PC so I can edit them.
Jan 30, 2009 | Symphonic WV806 DVD Player/VCR
No picture seen or recorded - only audio
I had a similar problem with my Sony 14E in that it would not record at all - sound or pictures. Prior to that I had the lines indicating head cleaning necessary. I did this, and still nothing. I then did the following which you might try.
1. Clean the heads (I did it about 3 times in the space of a couple of hours).
2. Leave the camera tape section open (with or without the tape in) for a couple of hours and the camera in a WARM PLACE. I had condensation message prior to my problems too.
3. Put in a recorded tape and attempt to view it. Immediately I had the "dirty" lines for a few seconds then it played the recording.
AT THAT STAGE I TRIED TO RECORD - NOTHING.
Repeat Steps 1 - 3 because this seems to be about dirt and cold.
4. When step 3 is reached again! try to record. Eventually this worked for me.
I hope this helps and works for you.
Jan 03, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
My Sony dual tape deck does not record in stereo anymore.
Oxide deposits on heads can restrict audio transfer to tape. You may need to do a deep cleaning of record head. Depending on how much deposits are on heads may need no more than alchohol and Q-tip. Be sure to clean erase head and drive roller. Afterwards, try recording, then use headphones in jack on recorder to check for recording on both channels. If this works, problem is not in rest of equipment set up. If you still need help, email me
Apr 21, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Panasonic DMRES20D wont record
I had a similar problem just over a week ago. Buying brand new DVD-R discs seems to solve the problem but I have had to throw one disc away.
Apr 07, 2008 | Panasonic DMRES20D DVD Recorder
if you take it to best buy or future shop they should be able to fix it there
Feb 11, 2008 | Audio Players & Recorders
Blank disks won't record
FIRST HAVE THE LASER LENS CLEANED
THEN USE MEMOREX DVD-R THIS SHOULD SOLVE YOUR PROBLEM
Oct 20, 2007 | Panasonic DMR-E50 DVD Recorder
Sony TVR 19, Not playing back
had a similar problem a while ago, took the camcorder to repair. the problem was that the reading-head (the part that is incharge of reading the tapes) needed cleaning. i used a cleaning cassette - problem solved.
Sep 14, 2005 | Sony DXC-190 Camcorder
Philips VR550 VHS VCR Logo
485 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
