Question about Xerox WorkCentre XE80 Laser Printer
E2 Paper Jam code flashing .... but no paper jam!
The copier is showing the error code E2. But we've taken it apart at the back and at the front as suggested in user guide and no paper jam to be found. But we cannot clear the error code. Any ideas so we can use it again?
  • arainy Sep 15, 2008
    I understand the fuser has become dislodged, however, I do not know how to take it apart to fix the fuser. How do I begin to take it apart?
    President:
  • 2,072 Answers
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Posted on Apr 14, 2008
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
It won't work and has an Error Code E2?
Dear Shaun McKenny, I just posted a fix to a Error Code E3 which is a paper jam that had no visable paper jam..Try this...it may be that you have some kind of paper stuck in the rollers...and you just can't see it ! Turn printer OFF for at (10 Seconds) then turn it back ON and listen to hear the Feed rollers turning and Force FEED a sheet of paper into your printer...until it catches and pulls the paper through and see if some scrap of paper comes out with the
sheet ? GOOD LUCK ! Let me know Phil at
palcando@yahoo.com
If this works for you, spread the word !!
May 04, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Riso 3700 - Error Code G064
1 Power  swich off/on
2 Open and close front cover twise
Mar 22, 2009 | Office Equipment & Supplies
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Error message shows e2 but there isn't a paper jam anymore
Hello sir; try to turn off the power and turn on, if still don't work, you have to check the sensor it located where the paper got jam,
Jan 10, 2009 | Xerox WorkCentre XD120f Copier
Error code J00
Code J00 is paper tractions error, either one of the traction wheel or one of the sensor is stuck or defective, often you need to take apart the printer to fix this.
Jan 07, 2009 | Kyocera KM-1510 Copier
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Xerox WorkCentre XE80 Laser Printer Logo
579 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
