Question about Sony Cyber-shot DSC-S700 Digital Camera
Magicgate memory stick wrong format
I have deleted pics from Magicgate memory stick now it says wrong format - can this be fixed or have I broken it
  • 106 Answers
ACTUALLY LOOKS YOU HAVE DELETED THE DEFAULT FOLDERS OF PICTS IN MEMORY STIC, NOTHING TO WORRY JUST REFORMAT THE CARD USING THE CAMERA AND IT WILL WORK FINE
Posted on Apr 14, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
The disk is write protected
You only can use Memory Stick Duo. There is a write protection switch on the memory card, you only can switch with a sharp point. Ball point or something like that. Have a close look on the card.
"Memory Stick Duo", "MagicGate Memory Stick Duo" and "Memory Stick PRO Duo" are equipped with MagicGate functions.
MagicGate is copyright protection technology that uses encryption technology. Data recording/playback that requires MagicGate
functions cannot be performed with this camera.
So if you have a MagicGate one it does not work and could give this error.
Nov 06, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
My 4gb memory stick pro duo didnt work on sony vaio vpcw21eag card reader magicgate hg duo.. pls help me... my operation system win 7 ultimate.. help me...
if your 4gb memory stick are not working,i suggest format your 4gb memory stick and use. step for format it , Right click on my computer and click on manage after open manage window click on Disk management tab after few second your 4gb memory stick are display it, right click on 4gb memory stick and format, select quick format , ok after few second complete format message are display , click ok and use your 4gb memory stick.
Jun 22, 2011 | Computers & Internet
What tyue of memory stick do you need for a eclipse head unit and does it need to be formatted to play mp3
Memory Stick Playback Features
Compatibility: The AVN5495 can only play music data recorded in ATRAC 3 on MagicGate Memory Sticks (white). MagicGate Memory Sticks and standard Memory Sticks can also be used for database updates and ESN. Memory Stick Duo must always be used with the Memory Stick Duo adapter. Memory Sticks with a capacity of up to 128MB are supported. Memory Stick PRO is not supported.
Mar 11, 2011 | Eclipse AVN5495 Car DVD Player
My memory stick does not have a lock or unlock position.
Do not use the computer to erase a memory stick. If your pics are safely on the computer and you want to completely erase the stick, use the format function in the camera.
Apr 25, 2010 | Sony Cyber-Shot DSC-P92 Digital Camera
Memory stick error, what does this mean, What can
Two things to try: 1. Get a separate card reader and use it to download the pics to your computer. 2. Take the card to Walmart and plug the card into a Kodak Picture Kiosk machine. You can print the pics or even make a cd of them. Once you safely have your pics. put the card back into the camera, go into the menu and find "format"..follow the on-screen instructions to erase and initialize the card. Everything should be back to normal.
Apr 18, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
I HAVE SOME CORRUPTED DATA IN MY MEMORY STICK
check if magicgate in your memory stick is supported, if not...it´s an alternative MS...but you can try to format all your memory stick using your psp , PS3 or even with a pc MS card reader...re-install all ms softs...
Sep 14, 2009 | Sony PlayStation Portable (PSP) Slim...
No memory space in memory stick
You can delete pictures from the camera. You can transfer the pics to your computer, then delete. Plug you camera into your computer, click start/computer/ double click on the drive that accesses your camera. From here, you can drag/drop pics or delete them or format the entire memory stick. If you need all of the pics and do not have a computer, you will need to purchase another memory stick.
Please take a moment to rate my answer. Thanks.
Apr 28, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
New psp
use only magicgate/sony brand memory sticks , must format memory stick,......Have u saved anything on it????
Sep 29, 2008 | Sony PlayStation Portable (PSP) Console
Clie T615 not reading memory stick
Either the stick is defective or the wrong format.
May 04, 2017 | Sony CLIE PEG-NX60 Handheld
Sony Cyber-shot  DSC-S700 Digital Camera Logo
491 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
