Question about Cameras
Nikon D40x AF-S Nikkor 18-55 mm 1:3.5-5.6 GII ED Lense Trouble
Hi, My 18-55mm lense (see info in subject line) will auto focus but will not shoot. It makes a squeeling noise when I push the button. It will shoot on manual but does not focus. Can you tell me what the problem is. I use this lense the most and really need it. Thank you.
Rachael
  • 4 more comments
  • Anonymous Jun 24, 2008
    On my D40X the AF-S Nikkor 18-55 lense has stopped working with autofocus instead just makes a noise and won't take picture. If I switch to manual focus the camera takes picture, though it is out of focus. I can't figure out how to use manual focus with this lense. Camera works fine with my 55-200 lense (auto and manual focus).
  • morenaloca Jul 03, 2008
    I have the same problem with my lens.
    When on auto focus it sometimes decides to not take the picture, until I switch to manual focus mode. I did not experience any noise, but the auto focus not working is very bad during photoshoots.
  • galen vinson Jul 22, 2008
    I too am having problems with the auto focus on my Nikon 18-55 AF lens,this was purchased with a D-50 from my daughter and I gave her my lens a 18-70 AF from my D70, basically the same as the others. I have to say however I have used this lens alot. I shoot alot of buildings and things which a wide angle lens is good for and the lens has been working since 2005 without any problems up to now. My question would be is this something that can be repaired ?
    galen vinson
  • dentedup Aug 14, 2008
    I've had the same difficulty with mine. Missed a few great shots because of it too. I'm not sure what do to with it...if I were to sell it I may end up with an unhappy buyer.
  • andy298 Dec 28, 2008
    I have recently developed the same problem. My 18-200mm DX VR has worked perfectly until now. It now makes a noise like it is trying to focus but does not and it will not take the picture unless I manually focus. I hope it is not damaged because this lens was not cheap.
  • Anonymous Feb 05, 2009
    same exact problem as the original post, but my lens and d40 are brand new! sometimes if I jam it in harder (the little switch on the lense to change from a to m) it will work but most of the time its useless
I've found the same thing with my D40x and the 18-55mm AF-S lens. I took a really close look at it and found that the mount on the lens is badly worn on all three of the bayonet tangs and one is cracked at the base. What happens in my case is that the lens has movement when mounted on the camera - just enough to stop the contacts from mating properly. Hence, no photos. Am taking it to Nikon to get it fixed. I suggest if this is your problem, that you take it to the repair man.
Posted on Dec 10, 2008
I had the same problem with my 18-55mm lens on my Nikon D40x. I wiped the lens bracket with a soft cloth and now it works.
Posted on Oct 31, 2010
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
When trying to take a picture the lense moves back and forth trying to focus. When it finall stops the subject is out of focus. There is a grinding sound as it tries to focus. Some times the picture will...
It sounds like you need a new lens. This particular camera does not have an autofocus motor built in, which means it can only use lenses that have a motor already built in. Look for any Nikon lenses that have the AF-S in their name.
Amazon Search for "Nikon AF-S": http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Nikon+AF-S&x=0&y=0
This is also a good "general use" lens: http://www.amazon.com/Nikon-18-55mm-3-5-5-6G-AF-S-Nikkor/dp/B000LWJ1ES/ref=sr_1_10?ie=UTF8&qid=1298926690&sr=8-10
Hope this helps.
Feb 28, 2011 | Nikon D40x Digital Camera
Using auto focus 35-55 mm lens on d40x will not take picture but if I use manual focus, I can take picture.
It is because the lense is only an AF lense. The d40x doesn't have an on-body auto focus motor so that needs to be on the lense. I have a d60 and have the same problems. You can use the manual focus on the AF lenses; however, to use auto focus, you need to buy an AF-S lense. It's disappointing I know, but that's the price we must pay for saving on our body lol
Jul 20, 2010 | Quantaray 135-400mm f/4.5-5.6 for Nikon AF
Nikon 18 to 55 lens wont focus
Check to make sure the manual focus/auto focus switch on the lens is set to A. Make sure the lens is completely mounted to the camera and locks securely. If this does not help, or if the lens was dropped, then you should consider buying a new lens. the cost of fixing the old lens may be at least half of the cost of buying a new one.
Nov 12, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikkor lense
You need AF-S or AF-I Lenses. These have the autofocus motor built in to the lense. The D40 and D40x does not have an autofocus motor in the camera body itself, while the D80, D300, D3 Etc to have the motor in the camera. You can use most old lenses on your D40x, but you will have to focus them manually.
See Ken Rockwells page for a lot of D40 / D40x info
http://www.kenrockwell.com/nikon/d40.htm
Jun 03, 2008 | Nikon D40x Digital Camera
Cameras Logo
2,795 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
