Kenmore 63942 Dryer Logo
Posted on Jun 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore electric dryer not heating
I checked the power with a meter coming into dryer, everything looks good. I checked for continuity acroos themostat with ohm meter and it looks good. I checked continuity accross heating elment and it does have continuity. Can the problem still be the heating element even though I have continuity?
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Jun 21, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10835180
Points
101584
Hi, If you have a gas dryerKenmore electric dryer not heating - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gifKenmore electric dryer not heating - 2_bing.gif rel='nofollow' href="http://www.fixya.com/support/t4734648-dlg5932w_not_drying_completely_hear_gas#">electric2_bing.gif..
There could be a number of different prKenmore electric dryer not heating - 2_bing.gifbr />Check out this tip that I wrote about this problem...
DryerKenmore electric dryer not heating - 2_bing.gif/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
2helpful
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Kenmore Elite Oasis Dryer is not drying. No Heat
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Kenmore Dryer # 86984110 Will not get hot
I have a Kenmore electric dryer mod. # 110 62912100 everything works well however it does not heat up, only blows cold air. Is this something I can repair myself?
Oct 27, 2009 • Dryers
Dryer will not heat on stackable kenmore washer
Oct 15, 2009 • Dryers
No heat from Kenmore 400 Electric dryer
5helpful
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
Dryer wont run
Check the door switch for continuity.
Check the thermal fuse on the heat canister for continuity.
No continuity, bad part.
I have a Kenmore Elite Model number 110.64992300. The dryer turns on and spins but does not heat. I have the bottom panel off am looking at the heat element. What should I do to test everything? I have a...
You need to make sure you have 220V first all the way to the dryer. Make sure you have no blocks (lint blockage). Check your thermostats for continuity. Make sure all the wires are disconnected when testing. If they show good check your heating element not only with the ohm meter but take it out and visually inspect it. They can be bad and show continutiy.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
