Xerox Fax Centre F12 keeps giving me error code E3 when I am trying to receive a fax from one particular client. I can receive faxes from others without problem, and this client says he can send faxes to others without problems.
    President:
  • 2,072 Answers
Looking through all the service documentation and engeneering tips, and also searching the Xerox.com database, I find no E3 code for a F12.
Do you have the ECM mode on your mechine set to "ON" ?
That is the error correction mode.
I really can't find an E3 message in service documentation.
I will download a user guide and see if I can find it there.
Posted on Apr 14, 2008
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
I can not receive fax but i can send fax the printer hp officejet5610 was at the client he receive the error that says fax fail brought the printer to my workshop the printer gives the same error please...
Hi, Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code.
  1. To modify the fax header, use the following steps:
    1. Press Setup on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
Regards,
Riztech
May 23, 2011 | HP Officejet 5610 All-In-One InkJet...
I use my fax daily to receive faxes. I have one client who faxes me and it takes hours for it to print and either errors or prints a blank page. Right now I am waiting for a fax to print out that was...
Your client probably has a phone line problem causing errors.
The first test is to send a FAX to that person. Does it proceed normally?
They may share the line with a telephone or other device. IF they have DSL they MAY have forgotten to put a DSL filter in line for the FAX.
If they send the FAX from a computer there may be MANY other reasons the computer hangs up.
Mar 15, 2010 | HP 1040 Plain Paper Inkjet Fax
Phaser 6180 error code 033-762 Fax not recieving
possibly junk fax feature is ON which assumes every fax you receive should have sender fax numer pre-registered, otherwise it just rejects the fax sent from an un-registered number
Jan 05, 2010 | Xerox Phaser 6180N Laser Printer
Paper jam, error message, fax send comes out not ledgable.
Code 43 is a line error according to Panasonic.
I had this issue trying to send to a client yet I could send faxes to other #'s. So in my case it was a dead fax on the other end of the line.
Jun 13, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Trying to receive a fax. Getting a message "processing has been cancelled due to an error" Gives me fault code 024-747. Help... what do I do???
If this is a Xerox fax machine, that specific error code states:
An invalid print parameter combination was set. Check the print data. For example, a custom size was specified, and [Paper Supply] was set to [Auto]. In this case, select the bypass tray.
May 01, 2008 | Office Equipment & Supplies
Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Sep 11, 2007 | HP Officejet 7210 All-In-One InkJet...
Fuser Error
If your unit is out of warranty, sadly but true go get a new equipment. Xerox will probably charge por parts and service almost what you paid for the equipment.
Oct 25, 2006 | Xerox WorkCentre Pro 580 Plain Paper Laser...
240 people viewed this question
jasbo
jasbo
