Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Hoover Savvy runs but has a burning smell...
Just out of the blue it started smoking and was followed by a mechanical burning smell. Wasn't cleaning anything up out of the ordinary but regular vacuuming. Took the whole thing apart and can't figure out where or what is wrong. Turned it on and the same thing. Where do I start looking?
    President:
  • 1,673 Answers
Could be that the motor went bad, or one of the circuit boards is bad. The brush roll motor is the likely suspect.
Posted on Apr 15, 2008
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
Apr 02, 2014 | Hoover U5750-900 WindTunnel Bagless...
Hoover U6434-900 started smoking while vacuuming. Now it will not start. Waiting 30 mins for the reset but still wont start.
Check the drive belt and then check to make sure the cleaning bar is free of hair. This will cause a burning smell. I know, I raised 4 girls.....
Nov 04, 2013 | Beam Industries 2900 Serenity Plus Central...
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Drive and brushes stopped
Look for a missing belt that may have burned off or broken. Was there a burning smell at some point before the roller quit turning? If so, the belt must be replaced. I would also look at the ends of the roller to see if there is any string, hair, etc. that might be binding the roller that needs to be removed.
Jan 24, 2009 | Hoover U8125-900 Savvy Bagged Upright...
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Savvy Model U8181-900 Rewiring
The brush roll motor is most likely what caused the problem to the circuit board. You would look at about $100 or so for the 2 parts.
Jan 16, 2008 | Vacuums
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
191 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
