Question about Intel Motherboard
Computer problem in my computer i m not getting a option by with i can access cd drive? previously i was getting option cd drive g in my computer option but its not there
  • 165 Answers
Some intel mobos need sata controller set to legacy mode in bios to access ide cdrom drives.
Posted on Apr 30, 2008
  • 106 Answers
Your OS HAS GONE CURRUPT...RQURES A REPAIR AND IT WILL BE OK, BEFORE REPAIR JUST LOOK IN DEVICE MANAGER THAT ITS AVAILABLE THERE.
Posted on Apr 14, 2008
What web site can i use to get a reboot cd for my computer
You can make a boot cd on most any computer that should work on your computer. If your looking for a restore disk only the manufacturer of your computer system can provide that, you would have to go to their website to see what options they offer. If you just need something to repair a Windows boot problem use your Windows installation cd. Most the major companies put a restore partition on the installed hard drive you can access by pressing F8, F10 or F12 while the machine is starting up. Sometimes you have to go into the system bios menu to get this option, HP computers do this. Press ESC then from the menu press your desired option. If your BIOS is not set to check for boot media in the CDROM before the Hard drive you'll have to change that. I recommend you set the boot order to Floppy, CDROM, Hard Drive then if the option is there the USB would be your last selection in the order.
Oct 11, 2010 | Computers & Internet
How do i reset my hp computer back to the way i bought it?
factory settings could mean performing a system restore to a previous state of the OS. I'll try to explain how you can perform each one of these methods in the article below.
Restore Factory Settings - System Restore System Restore is the in-built tool of Windows XP and Windows Vista that allows you to roll back the registry to a previous state. Note that it only "restores" previous settings for the registry and Windows system files.
You can use system restore to get rid of spyware, but if system restore does not fix your problem, you'll have to resort to either a clean install of the OS or using your recovery CD/DVDs.
You can read my previous post on how to restore your computer using the System Restore feature. If system restore is disabled, you can read my post on how to enable system restore again.
Restore Factory Settings - Recovery CD/DVDs Most computers come with either a recovery CD/DVD or a recovery partition that is hidden on the computer. This is true for most HP and Dell machines now these days.
If you have one of these, you can access the recovery from within Windows or during startup.
For HP, you can go to Start, All Programs, HP Tools, and then choose HP PC System Recovery.
You can also press the F10 key multiple times during bootup to get access to the recovery console in case Windows is not loading properly.
On Dells, you can access the recovery partition by pressing Ctrl + F11 immediately after the machine is turned on.
Note that all of your data will be lost on the hard drive. Using a recovery CD is not the same as repairing XP. When you repair Windows XP, all of the system files are replaced with the original ones, but your data and applications remain intact.
Restore Factory Settings - Clean Install XP Your last and final option for restoring XP to factory settings is to perform a clean install. This requires having the CD/DVD for the OS. If you only have a hidden recovery partition, you will not be able to perform a clean install.
A clean install basically consists of booting from the original XP CD, deleting all partitions, recreating new partitions, and then installing Windows XP from CD.
It's a fairly straight-forward process and you can read this excellent tutorial for step by step instructions. Again, it's important to note that you will lose all your data in this process.
Oct 05, 2010 | Computers & Internet
I have an HP Pavilion dv6000. I recently tried to free up some space by uninstalling some programmes. I accidentally seem to have removed whatever connencts the computer to the dvd/cd drive & cannot...
Such errors may occur, if accedently you uninstalled the required drivers for the device.
Now you can use the System Restore Option to get it working again :
  1. Click on Start Button,
  2. Go to Programs
  3. Point to Accessories
  4. Then go to System Tools
  5. Now you can find the System Restore.
Start System Restore and find any previous date shown in BOLD. choose that date, and you'll get your system restored in the working condition as earlier.
Jan 21, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have got a 2gb scan disk memory card i cant access it or format
Hello Friend,
Here is a method to try:
  1. Backup all data from your hard drive to another hard drive or CDs or DVDs.
  2. Turn off your computer.
  3. Insert the USB drive to a USB port.
  4. Turn on your computer.
  5. Hit the F8 key when prompted to get to your system bios. Some computers required the Delete key or F2 instead of F8. There should be a note on the screen that specifies the key.
  6. Navigate your bios (usually using your cursor keys) to boot from CD drive first. Save and exit.
  7. Insert your operating system disc aka Operating System Restore disc. Your computer should restart. If not, restart it yourself.
  8. Follow the instructions for installing your operating system. When the option to select which drives to format comes, you should be able to see your USB disk in the list.
  9. Format the disk with FAT32 for Win98 or previous. Format with NTFS for anything after e.g. NT, 2000, XP etc.
  10. Depending on your options, you may be able to opt out of the operating system install at this point. If it was running well beforehand and you can, leave your other drives alone and quit the re-installation.
  11. Reset the computer to boot from the disc drive the operating system is on instead of the CD drive as before. You should have your working flash drive detecting and usable now in windows.
  12. If you didn't get the option to opt out of the re-installation, continue to follow the instructions onscreen and complete the re-installation, formatting whatever drives are required. Note: Do not try to install your operating system onto your USB disk drive. Also be cautious when formatting to keep in mind all data could be lost.
Best Regards,
Oct 29, 2009 | Electronics - Others
How do I get to the Command prompt on the dell
Sorry to say but actually your windows has become corrupted, may be due to improper shutdown or power failure. do one thing try to start your windows with previous known configuration that worked .(option already available on boot screen).if this does not work enter your windows cd and choose repair windows option when prompted.follow the instruction that proceeds.you will recover previous status of your pc.
Oct 20, 2009 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
I can't download music from CDs. What do I do?
1. If the CD/DVD drive tray not open.
Open "My computer" windows and select the CD drive . "Right click" on the CD drive.You will get a pop up windows with the "Eject" option.
If it open that's means the power supply is ok
2. If the DVD drive is not showing on my computer windows or the DVD is not detect the CD/DVD disk.
To fix the problem we need to delete the "UpperFilters" and "LowerFilters" registry key for more details about the troubleshooting step please follow the below link.
No longer access the CD drive or the DVD drive
3. If the cd/dvd is detected and you want to know how to copy the file from cd/dvd to the computer.
-Open cd/dvd drive and select those file by mouse what you want to download from cd/dvd to the computer.
-Then right click on the highlighted icon and select copy option.
- After copy those file saved on your computer.
Note:After follow the above steps if you still face the same problem then need to contact the local hardware vendor.
Jul 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Accessing restore partition
Most computers shipped prior to Mid 2004 do not have the restore partition (called PC restore). To check if you computer does have the restore partition, Right-click on “My computer” select “Manage”, on the left of “Computer Management” window click on “Disk Management” . On the right bottom, if you see three partitions (the third one without a drive letter) then you have the restore partition.
The following two steps will work only if you have the PC restore partition / OR if you have not reinstalled the operating system previously.
To get into the PC restore (if you have it) hold down <control> + tap F11, when the computer turns on, I,e after the Dell logo.
The second and simpler option (if you can login to the computer) is to download, save and run the following file http://tech.atjolie.com/BOOT_DSR.EXE . The will restore the computer in the PC restore option.
If both these do not work, reinstallation using the Win XP cd is the only option
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 27, 2009 | Dell Latitude D600 Notebook
Virus on computer
In order to remove really nasty stuff (like Trojans and the like), youhave to run a virus scan BEFORE your operating system loads.
What helped me was Kaspersky's Rescue CD, which is a bootable CD. You can find it here.
A good description how to do it can be found here.
If the virus is "well written", it will not let you restore to a previous point. Download the CD, burn it and start your computer from the CD. (You might have to change your BIOS settings to do that. In order to access the boot options, pressthe F10 key while the Gateway screen is displayed during the startupprocess. This opens a Boot menu with the option to start the computerto any of the available drives. Use the UP ARROW and DOWN ARROW keys toselect a menu option, and then press the ENTER key to start to theselected device.)
Mar 10, 2009 | Gateway 7322GZ Notebook
Acer aspire 3515 reboot
the error you are getting, is related to the computer not being able to find a logical Drive. ( Hard-Drive Or CD Rom ) this could be caused by either A Virus. Or a corruption in the operating System. ( Windows System File Et,c )
If you check your computers manual, or website or you can enter the computers Bios screen.
Look for an option to restore setup defaults or similar, and save and exit to cmos/Exit.
Also see if there are options for using system restore. ( this is where your hard-drive will contain a seperate partition ) to enable a set of backup files to be loaded and run.
If you have a wireless network connected, remove or disable, until computer has re-booted. As your system could have been taken over by a hacker or similar program/virus.
Thankyou for using Fixya.
Mike @ compurepair.
Dec 01, 2008 | Acer Aspire 5315 Notebook
My E-Machine is not even a year old and it has given me the "BLUE SCREEN OF DEATH" as I have heard it called. I tried to recover my previous stuff to a certain date. It still blue screened me. So...
do u have any error codes ? in the blue screen ?.. is it a ntldr missing ? .. .wow, thats an issue if u cant even boot from CD even after switching your BIOS settings.
this may be an option:
Bart-PE from USB Stick (follow link)
Apr 17, 2008 | Computers & Internet
Intel Motherboard Logo
20 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
