Question about SAMTRON 55V 15" CRT Monitor
Samsung monitor colour complaints.
Iam facing the colour complaints in samsung in some models.
BY replacing with the memory ic my problem is solving. but when i replaced with memory ic which is purchased from local market it is not working.I think some programming with that ic. tell me how to programme the ic .where can i get the software.
    Problem Solver:
  • 18 Answers
All you need to do is download ddc manager bye using ddc controller you can reprogramme micom...
Posted on Apr 15, 2008
Tip
Samsung ctr 56v model monitor does not working
I am a technician.
i was replace the memory ic, 7805 ic, micor ic, and driver ic.
but SMPS is good working.
on Jan 26, 2008 | SAMTRON 55V 15" CRT Monitor
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
Switching ON problem for Samsung (SAMTRON 55V 15 in. CRT)
Hi
You just replace the IC 7805 (transistor type ) near microprocessor IC It will solve the problem
- Suhas
Jan 26, 2009 | SAMTRON 55V 15" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung monitor colour complaints rectification regg.....
Hi, This is viswanath Ican give A/S Test Jig&Driver for All Samsung Monitors.It's Working Only Windows 98a36c108.jpg28f6cf1.jpg
Apr 30, 2008 | SAMTRON 55V 15" CRT Monitor
The Red Colour Loss On My Samsung SyncMaster 753 DFX
My Dear Friends,
I Understood the problem.
I will explain it a little briefly.
There is an Integrated Chip (IC) inside the monitor which gave RED, GREEN and BLUE ( Primary Colours) to the CATHODE RAY TUBE (CRT) otherwise called monitor screen.
Due to long run, the IC might be cold soldered and one or two of the colours will not be supplied by the IC to CRT. so the CRT (monitor) will fail to display and mix the primary colours to get othe orginal colour.
The SOLUTION is to replace the IC with a new IC. As this requires a little bit expertise, please get help from the monitor service technician and ask him to replace IC with a new one. This can be done in home, so that you don't have to take the monitor to shop or service center.
All the things you have to tell the technician is to come with a stand-by ICs (NEW) for the MONITOR MODEL, in this case "SYNCMASTER 753S".
It cost around Indian Rupees 300/- for the cost of IC and another 200 Rupees for the service charge of technician.
I hope you solve this issue, if not write to me at spiceprince@yahoo.com with all details.
Spice Prince
Apr 10, 2008 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Red color problem
As you are not able to see red color on your monitor means you will be seeing green+blue=cyan color your problem is that red signal is not coming to red cathode of your crt. please check 1 connector loose(cpu to monitor) 2 crt base loose. 3 loose or print or dry near red cathode circuit 4 red video output. 5 red signal from processor to red video is missing 6 processor ic. good luck
Sep 27, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
142 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
