Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Drying Center MCE8000AYW
I have a Maytag Neptune Drying Center MCE8000AYW. I am getting no heat when drying. There is no lint obstruction. I assume it is a heating element issue. How do I get to the heating element because it seems there are no panels to take off. What would be the typical cost for service on this vs. me doing it and how do I know for sure it is the heating element? Thank.
  • 1 more comment
  • Spikes dad Apr 17, 2008
    I have the same problem.How do I change the element?
  • jhnpzds Apr 16, 2009
    Everything seems to be working fine but no heat on electric dryer. Same model.
  • Anonymous Mar 19, 2014
    how to access drum
    Scholar:
  • 178 Answers
Email me a response to robert_fawbush@yahoo.com and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Posted on Apr 14, 2008
MAYTAG NEPTUNE DC MOD# MCE8000AYW
Your exhaust is gettting restricted and not able to remove the moisture from the clothes. Also check lint screen with very slow flow of water. If water rolls off wash filter good .. If water can't pass through smoothly then air is also having problem being pulled through as well.
Nov 15, 2016 | Maytag Dryers
All the lights are lighting up but when I hit thew start button i hear a click but nothing happens. Maytag Neptune Model# MCE8000AYW
If there's lint or a problem with the air passing thru and evacuating, the sensor within the system will not turn on the gas or energy to begin drying. Time for a service call.
Oct 08, 2010 | Maytag Dryers
Maytag MCE8000AZW Neptune Drying Center. Display
my bottom dryer the light dont come on or when i press start it wont start all i hear is a click...any solutions?
Jan 31, 2010 | Maytag Dryers
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Maytag mce8000ayw start button won't work
your starter button needs checked at least but most likely replacded
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Maytag Neptune DC Model# MCE8000AYW leaks water from the right side of drying center unit while using the "Wrinkle Release Hanging Dry Only" feature. The leak happens during the steam portion of the cycle....
Stop using the water bottle because the water is overflowing the heater steamer pan and will short the heating element and the part is no longer avaliable and the top will stop drying.
Mar 27, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag SDE515DAYW
could be a bad thermostat or power control board.
also make sure you getting the corret voltage otput at the wall socket using multimeter
Jan 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
1,526 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
