Question about RCA HD52W56 52" Rear Projection HDTV
RCA HD52W56 inneed of help no power
2 Other Users Have The Same Problem Comment by brian1968, posted on Apr 14, 2008 I have the same problem...I went to change the channel and the tv went off..I changed the channel again and the tv came back on..3rd time i changed the channel no more power..
No power with the remote or manualy ..No lights what so ever
We had same problem 6 days after we purchased this tv..A new tv was installed..now again same problem but the dealer said it would be cheaper to buy a new tv
Well i dont have 2k sitting around for another tv can some one please help me???
    Genius:
  • 1,030 Answers
Ok there is no light on front panel. doesnt blink or try to turn on? this is an indication of a main power interuption. as always the main fuse can be checked.
Posted on May 12, 2008
Have a hd52w56 when power up lcd blinks 3 times and then goes off... I have replaced the green tube(was cracked) and then was working . then the screen went green and the fuses popped, change the fuses and...
On your Deflection board it is the one on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up ont op it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v resolder all pins on FBT flyback transfomer.
Nov 10, 2009 | RCA HD52W56 52" Rear Projection HDTV
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Where is the part # located?
the main board or the signal board. this is the board in the metal box. this is also known as dm3 module its part is265949 the power board is 266862
Feb 28, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 in big screen
Does the power indicator blink when you press power? If so let me know how many times it blinks. Respond to this same post
Jul 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
Help!!!
so your firmware is good.... it's not the program,, ir's a hardware failure, you dont have signal...dont you have warranty ? co'z if you're going to the service center they are going to repair your parts. and once they do that youre going to loose your warranty. and fix that is expensive too..you might have faulty ( p.a. power ampli, or uem. power and audio ic.. tnx...
Apr 17, 2008 | Motorola Mobility RAZR V3
Laptop shuts down prox 1 minute into startup.
You can change it by rating his solution as thanks for trying or just denying it.Then rate or accept my solution as fixya.
Apr 04, 2008 | Toshiba Satellite A105 Notebook
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
Jan 01, 2008 | Zenith Z37LZ5D 37 in. LCD TV
HD52W56
take the cover off and look for something that is burnt and take a pic of it and attach it here.
Dec 11, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
