Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Bios password how can I remove the bios password besides removing the cmos battery and waiting overnight?
  • dick2256 May 28, 2008
    just happen to be lucky enough to have a bootable cd for win 98 that I had made before and it let me into do a fdisk and removed the password.
    didn't have a floppy drive I could use on that machine.
    thanks
  • 868 Answers
Some how get to command prompt,and fdisk the drive.
Posted on May 26, 2008
Cmos bettry cannot remove the bios password how can i remove the bios password
Did you leave the battery off for a couple of hours? Maybe even overnight if it's stubborn. If you left it off overnight and it did not remove the password, then you will have to short the jumpers. I would go to the dell support site and see if they have anything in the manual on the BIOS Password.
Apr 02, 2012 | Dell Inspiron 1300 Notebook
If cmos battery should not remove the bios password what should we do to remove the password
Apr 02, 2012 | Computers & Internet
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
How do i clear the bios password
turn off your unit,,then remove CMOS battery...the after 5sec put it back..
Mar 19, 2011 | Computers & Internet
Remove administrator Password.BIOS password
Hi
This is really, really strange but the BIOS password can be removed only by a local ASP. The technician will remove it and will update the BIOS to prevent such further, unexplained password settings.
Greets
Feb 11, 2010 | Dell Vostro 1500 Notebook
How to reset bios password , i forgot d password
Remove the battery on the mother board, wait 5 minutes.
Oct 15, 2009 | Fujitsu LifeBook P1120 Tablet PC
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
Dell latitude d620 power on password can't remove
No need to short out any pins, shorting out pins allow you to reset the BIOS quickly. When you leave the BIOS/CMOS battery out overnight, this will reset the BIOS (you only need to leave the battery out for 1/2 + hour to do the same thing).
Mar 29, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Will removing the cmos battery help remove bios password
Yes, if you remove the cmos battery and have your PC unpluged wait 2-3 mins before reseting battery it should reset the bio's.
Feb 24, 2009 | Dell Latitude 100L Notebook
I FORGOT MY laptop HP PAVLION 4000 SEREIS BIOS PASSWORD
see if you can locate a jumper beside the cmos Battery on the system board...
If yes, you will notice that its having three pins and has the inscription "1-2 cmos" , "2-3 clear"
If yes then remove the jumper from "1-2" to "2-3" and wait for about 5 to 10 seconds to clear the CMOS battery.
Replace the jumper to "1-2" and enjoy your default settings...
Get back to me if there is any problem....
Thanks..
Jan 08, 2008 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
484 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
