Question about Garmin nuvi 350 GPS Receiver
Garmin Nuva 350 GPS
USB port came loose and slid inside case
Can not reach with power cord
Any way to fix other than paying $175 and mailing to Garmin?
    Scholar:
  • 174 Answers
The USB port is soldered to the circuit board, it didn't slide in, it broke due to brute force. I think you have to fork out $170
Posted on Jun 10, 2008
  • gadgetlvr Oct 28, 2013
    These guys are really good at fixing a loose USB. Check them out www.nabilselectronics.com
Does not turn on with car charger
Common problem with the 13xx & 14xx is a loose USB port.
1. Check fuse in tip of charger.
2. Make sure lighter outlet works - no blown fuses.
A loose USB port will prevent power reaching the unit from the charger and will prevent the internal battery from being able to be charged. More information can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 29, 2014 | Garmin nuvi 1350 Car GPS Receiver
The power and mini USB connector on my Garmin Nuvi 200 has gotten loose and it will not hold the connection through the power cord without being held by hand. Is there a repair for this?
USB connectors are too fragile for the constant in-out service they get. But I have solved the "loose USB" problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Dec 29, 2010 | Garmin nuvi 200W GPS Receiver
12volt usb in the side of my Garmin now dead
unfotunately only an electronics expert can fix this if it is indeed salvageable. You basically have cooked the circuits with the power over load.
Oct 19, 2009 | Garmin eTrex Legend GPS Receiver
USB connector in the back is loose and will not
If the connector in the back is loose, its not a Nuvi 350. A nuvi 350 has the connector on the side. In any event, please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi350 won't power on from USB or power jack, works fine in car
Bad contacts with the mini USB port. Either the connector needs resoldered or replaced. Please see this link, section on loose/broken USN port:
- Jim
Jul 06, 2009 | Garmin nuvi 350 GPS Receiver
THE USB PORT THAT MY GARMIN NUVI 270 IS PLUGGED IN TO IS NOT RECOGNIZED BY MY COMPUTER
If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult to solder in a new USB port.
Sep 17, 2008 | Garmin nuvi 350 GPS Receiver
USB port on Garmin Streetpilot I2
If the USB port is loose, that means that the port has come of the circuit board. This happened to a friend of mines, his son did not look which way to orient the usb plug and used brute force. It will need to go back to Garmin for repair unless you are or know of an excellent solderer as the conenctions are minute. The case needs a TORX 6 screwdriver.
Jul 31, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
132 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
