Question about Dell Latitude D600 Notebook
Dell D600 My Dell D600 will only power up when the battery is removed. When I power up then install the battery it locks up. What do you suggest?
  • jrfranz Apr 14, 2008
    I tried a battery from another and it did the same thing.
  • jrfranz Apr 17, 2008
    I'm afraid to try the battery in a different laptop. It does lock up instantly.
  • Dell Master
  • 13,433 Answers
Is the battery faulty?
Posted on Apr 14, 2008
  • Ekse Apr 14, 2008
    and the battery works in another laptop?
    It would seem to be a motherboard problem. Unless you want to take the laptop apart or buy a whole new motherboard I would recommend useing the laptop without the battery.
    how long does it take untill it locks up? instantly? does windows start?
Why my dell latitude D600 notebook battery power goes off soon i start it?
That probably means your battery is bad. I would suggest buying a new one off of amazon. I'm personally not a big fan of e-bay.
May 19, 2014 | Dell Latitude D600 Notebook
My Laptop (Dell Latitude D600) when I'm trying to turn it on, can not swicthing on and no effect can show me that power is entring. I thounght that is charger problem and I trayed to use the same charger...
Try this, Unplug the power and remove the battery, while the battery and power are unhooked hold the power button down for 30 seconds, Put the battery back in and make sure you slide the locking tap to lock the battery in, try to start the computer, If it doesn't start, plug the power cord in and wait 3 minutes and try to start it, If it still will not start it has an internal issue and needs to be repaired.
Dec 01, 2010 | Dell Latitude D600 Notebook
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Dell latitude d600
    he battery is bad or a bad wire or take it in
    Nov 03, 2008 | Dell Latitude D600 Notebook
    Dell latitude d600 doesn't turn on
    The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
    Aug 15, 2008 | Dell Latitude D600 Notebook
    D800 will not even boot
    remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
    Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
    Apr 21, 2008 | Dell Latitude D600 Notebook
    Dell d600 video problem
    Forget the non-sense.
    1. Remove the battery
    2. Open the RTC Battery compartment
    3. unplug the RTC battery
    4. Press the power button to dissipate stray voltage
    5. Re-install RTC battery and cover
    6. re-install main battery
    7. Re-boot and enter set-up to change date time etc.
    Apr 17, 2008 | Dell Latitude D600 Notebook
    Dell D600 latitude will not power up
    you can try to replace the motherboard, which is apparently totally UnHappy
    Mar 16, 2008 | Dell Latitude D600 Notebook
    Dell Latitude D600
    remove the battery and adapter..keep the power button pressed for 10-15 seconds....again plug in the battery\adapter and turn it on...
    Feb 08, 2008 | Dell Latitude D600 Notebook
    Dell Latitude D600 Wont Start
    I would suggest removing the battery, then try powering the unit on. Many laptops will not start if the battery voltage is too low. Many batteries will read a lower voltage than minimal when they are at or near the end of their service life.
    Jan 08, 2008 | Dell Latitude D600 Notebook
    Dell Latitude D600 Notebook Logo
    Alun Cox
